Sudden appearance of vertical 3cm band on left of screen partly obscures the desktop and other pages. Worked perfectly last evening.
  • 13,433 Answers
This can be caused either by your monitor or the video adapter in your computer, other has a fault. Check your cables they may be loose.
Posted on Sep 13, 2008
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
My eee pc suddenly had screen problem a week ago--- when it boots up the screen is solid fluorescent green, then as Win XP starts there wide vertical bands appear, and finally what i'm left with is an...
I just had a smilar problem with the vertical lines and resolved it by disabling the display adapter, the display driver was corrupted, and i am using it to type right now and no problems. Go to the device manager and disable the disp0lay driver by right clicking on it and selecting un9install and restart. I could hardly see through the lines but I did it and it worked. Windows automatically comes with drivers from many manufacturers for many devices and it seemed it has one for mine and it worked as my display adapter is still disabled but my graphics are perfect....All the best!
Aug 17, 2010 | Computers & Internet
Signal degradation across vertical section of
This appears to be a common complaint on LCD monitors. Some LCD screens have control issues.
An LCD screen is the panel and a bunch of Line control chips wrapped around the outer edge. A problem with one line top to bottom or left to right is almost ALWAYS the LCD panel itself.
A problem with a fixed band (The band is in the same place at any resolution) is often the LCD but might be the signal driver chip (A large plastic pack with about 100+ leads). A person with a VERY small soldering iron might be able to resolder it, but they MUST know what they are doing. (board must be heated, lead free solder, eye like an eagle...)
If the band moves around or changes width, it is the signal chip or the power supply to it from the power board.
It can be software if there is a firmware upgrade. This takes a shop.
Mar 19, 2010 | iiyama Computers & Internet
Large band has appeared on display
hold ctrl, alt & delete and then close it when the task manager appears.
Jan 18, 2010 | Compaq Presario CQ60-220US PC Laptop
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
Vertical bands on right half of screen, left half perfect.
its usually replaced along with the ZSUS board
replace that and it should solve the problem
its not hard to locate that both
with the back cover open its to the right side of the kinda
kinda looks like the YSUS board
not hard to find at all
Jun 02, 2009 | HP PL4260N 42 in. Plasma HDTV
Very faint vertical bar moving across plasma screen.
OK... Left to Right is weird. I'd say one of two things.
Refresh Rate might be to low or to high, but i doubt this to be the cause. I'll put my money on external interferences. Something like another PC screen? TV? anything magnetic and I've even in some cases noticed PC side panels too close to a screen can cause this.
Dec 29, 2008 | Computers & Internet
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
Vertical band on new monitor
Without a second thought, send it back.
When you say the monitor has not be dropped, wht you are really saying is it has not been dropped by you.
There were alot of hands involved in getting it from the production line to your house.
At any stage it could have been dropped or given some form of impact (normally in transit)
That fault is in the panel itself and cannot be fixed.
Nov 06, 2006 | Dell UltraSharp 1907FP 19" LCD Monitor
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
