Question about Nikon COOLPIX L18 Digital Camera
I want to turn of the flash for an indoor picture how do I do this
  • 489 Answers
Push UP on the lightning bolt located right above "OK" on the back of your camera until it shows an icon with a circle around and line through the lightning bolt.This should force the flash OFF.
Hope this helps.
Thomas
Posted on Sep 08, 2011
Testimonial: "Thank you so very much ! You are better than the makers of my camera!"
  • Thomas D.
    Thomas D. Sep 13, 2011
    No worries, happy to help!
    Thomas Drayton
    Owner, Darntoothysam.com
    Affordable Digital Camera Repair
SOURCE:
Taking indoor pictures with no flash
If you're in one of the PSAM modes then don't pop up the flash.
You can use the Auto-No-Flash mode by turning the mode dial to the position after the green Auto mode (a lighting bolt in a circle with a slash through it).
Oct 07, 2014 | Nikon D90 Digital Camera with 18-105mm...
Cant get good indoor pictures with my i634
the key to good pictures anywhere is lighting. either turn on as many lights as possible, or set your flash to 'always on' (as opposed to auto). if your lights are yellow, you will probably want to use the flash anyway.
Nov 29, 2011 | Polaroid i634 Digital Camera
My pictures are over exposed,too much light.Faces are pale white,what setting should I change? pictures were taken indoors.
If using flash try turning down the ISO setting to 100. Also change the White balance to the Indoor setting if you cannot manually set that.
May 04, 2011 | Panasonic Cameras
My camera doesnt' work indoors. i try to take a picture and it doesnt' take when I'm in AUTO mode. However, when I'm in LANDSCAPE mode the pic will take. it seems like the flash isn't active in AUTO...
You must have a software glitch because the flash is supposed to be in the auto mode when the selector is in auto, unless you manually turn the flash off and the flash should go back to auto every time the camera is turned off and back on. Here's a work around. Turn the dial to indoor and use the flash button on the ring to set the flash to auto. In the indoor setting you can set the flash to on, off, or auto.
Dec 19, 2010 | Canon PowerShot A720 IS Digital Camera
A630 Indoor pictures are too dark in Auto, Flash
try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
Oct 07, 2009 | Canon PowerShot A630 Digital Camera
Indoor picture too dark with flash
Hey Jewdeit,
The built in flash on the K100D has guide # of 52 at iso 200 which does fine for close-up photography and as fill flash outdoors, but is not a powerful enough flash for shooting far away subjects indoors. What you probably should do is purchase an external shoe mounted flash such as the AF540FGZ which has a much higher guide number of 148 at iso 100. When shooting with flash if you are using aperture priority or full manual you can also try opening the aperture to let in more light that the flash put out, but doing this might over expose anything in the foreground.
Sincerely,
Allan
Go Ahead. Use Us.
May 06, 2008 | Pentax K100D Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
81 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
