Question about Westinghouse Washing Machines
I have a ld850sa03 washing machine that only agitates in one direction maybe gearbox failure,if so where do i get one,can you help
    Genius:
  • 1,239 Answers
Hi In most cases, motor malfunctions should be handled by a professional; do not try to fix the motor yourself. If the motor is a universal motor, however, you can change worn carbon brushes when sparking occurs, as detailed in the how to repair appliances article. To save the expense of a service call, remove the motor from the washer and take it to a professional service person, then reinstall the repaired or new motor yourself. To access the motor, remove the back panel of the washer. The motor is mounted on an adjustable bracket.
There is one other motor problem you can repair yourself. Washer motors usually have an overload protector clipped to the motor. When this component fails, the motor won't work. Before you take the motor in for service, test the protector with a VOM set to the RX1 scale. Disconnect one electrical lead wire to the protector and clip one probe of the VOM to each protector terminal. The meter should read zero. If the needle jumps higher, the protector is faulty and should be replaced. Pry up the protector with a screwdriver and replace it with a new one made specifically for the motor or washer. Connect the new protector the same way the old one was connected.it is not gear box.............
Posted on Sep 13, 2008
Washer quit agitating?
Check the belt or the main gearbox for damage.
Aug 26, 2014 | Maytag Washing Machines
How can I bypass the door lid latch on my top loading frigidaire washing maching. It will fill up and spin out but will not agitate.
I would not recommend bypassing the door lock switch it is there for your safety!
It sounds like there may be a gearbox problem underneath the machine which agitates the wash, Or maybe a simpler answer that you have a fan belt gone !
With power off remove inspection panels on the back of machine and check for fan belt.
you may have to look underneath if so make sure machine is empty then turn on its side have some old towels at the ready for any residue water from the machine .
I hope this is of some help?
Best of luck!
Jun 15, 2013 | Washing Machines
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
Washing machine operates sporadially
What made you replace the motor? Sounds also like a transmission problem. You motor reversing in spin but gears for agitate stripped in gearbox. Double check motor/coupling alignment. Pull the motor back off and turn the gearbox drive shaft both directions. One direction makes the basket turn, the other direction makes the agitator turn. If the agitator does not move, the gear case is bad.
Feb 17, 2010 | Washing Machines
Agitator sounds as if it's stripped
The agitator and drive gearbox are all one part and are not serviceable (sealed), if it is the gearbox the machine is possibly scrap as the part is more expensive than a new machine. Will need further investigation.
Is the spin OK (quiet) the motor rotates one way to agitate and the other way in fast to spin, the belt may be removed at the middle pulley (Below) rotated in each direction to test. try the machine without the belt and listen to motor.
Nov 25, 2009 | Admiral AW22 Top Load Washer
MY KENMORE WASHING MACHINE IS NOT SPINNING. THOUGHT IT WAS THE BELT AND CALLED THE REPAIRMAN AND HE SAYS THAT IT DOESN'T HAVE A BELT ON IT. DOES ANYONE KNOW IF MODEL #110.91110100 HAS A BELT?
Hello, Yes, the repair tech is correct. This model washer does NOT have a drive belt. It uses a gearbox driven directly by the electric motor. It is likely that the gearbox has a stripped gear or a broken drive wheel.
I've attached a link to the Sears parts web site so you can look at all the line drawings and parts diagrams for your washer model. You can click on each link to see the various components and also get a replacement parts list, which shows the prices (if you buy them thru Sear's site) to give you a better idea of the anticipated cost to replace the gearbox, etc.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.91110100&=part+number
Just click on the link titled, "BRAKE, CLUTCH, GEARCASE, MOTOR AND PUMP " to get a good look at the parts that make the washer agitate and spin.
You might want to take a closer look to see if it a gearbox issue or maybe a motor drive shaft problem where the keyway has sheared off and is causing the washer not to spin. If, however, the washer agitates during the wash cycle, the problem is NOT a stripped keyway on the motor shaft, but rather is within the gearbox and you'll have to either repair or replace the gearbox to get the washer working properly again.
The decision to undertake the repairs or purchase a new washer is yours to make, but I can offer the following to help you decide. If the parts (and labor costs, if you don't do the repair yourself) exceeds 60% of the cost of a new, comparable machine AND the machine is over 8-10 years old, AND you've got rust starting to appear inside the wash tub, etc. you might wish to seriously consider replacing your washer with a new one. Otherwise, go ahead and make the repairs and keep it working for (hopefully) many more years to come.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Kenmore Washing Machines
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Mar 13, 2009 | Washing Machines
HOOVER 510 PREMIER WASHING MACHINE ABOVE THE BELT SHAFT THERE IS A PLASTIC COG WHEN THE WASHING MACHINE IS ON WASH CYCLE IT SPINS FINE ONE WAY THEN ON THE REVERSE SPIN THER IS THIS ORANGE LEVER THAT MAKES...
I imagine you've bought a new machine by now? The plastic gearcog is the clutch housing. The arm that clicks is part of the brake lever. On these models, the brake lever is supposed to hold the clutch in place during the wash cycle so that it slips in both directions to get a forward and reverse wash. On spin, the lever moves away releasing the clutch and gearbox brake and allowing the bowl and agitator to spin together. The brake lever wears and allows the gearbox to slip during the wash cycle. When this happens, the clutch housing will "ratchet" past the brake lever tongue. this causes the "clicking" noise in 1 direction.
Oct 17, 2008 | Hoover Washing Machines
Hoover washing machine 550mb keep stopping on spin dry cycle.
Hi are the clothes tangled up around the agitator if so the gearbox may be faulty or the brake may be worn,is it washing in both directions
Oct 09, 2008 | Hoover Washing Machines
Hoover Washer only agitates in one direction
Check the paw. It is a plastic somewhat u shaped piece that sits on the bottom of the machine and is connected by a plastic lever and a solenoid. It usually breaks on the end and as such won't lock the gearbox in. If you keep running it like that there is every chance you will probably burn the motor out.
Oct 08, 2008 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
