Question about HP Office Equipment & Supplies
Can not close door on cd/dvd - HP Office Equipment & Supplies
    Genius:
  • 2,120 Answers
Punch the front of the door. The mechanism is probably broken anyway.
Posted on Sep 13, 2008
My dvd/cdrom driver cant sense or play any CD or dvd.even the door cant be closed?
if the door can't be closed, it is pretty much a done deal that the drive is shot. replace it
Sep 25, 2010 | HP Compaq DVD Drive
CD tray not opeing
Perhaps it didn't fully latch so the CD drive doesn't think it's closed? Try opening and closing the door manually by straightening out a paperclip, then inserting it into the little hole in the front of the CD door. That should open it. Once open, close it and see if it will now open when you press the Open/Close button.
Aug 26, 2009 | Acer (KV.16X04.007) DVD Drive
My laptop (Samsung R60plus) DVD drive door stays open while powered on, but remains closed while shutdown. D OS recognises it, i can play cd and install programs while holding d door. Pls what can i do to...
The problem is the micro switch that opens the door is allways on.... try press it 10 or 20 times to unlock the switch or try to clean it.... It will work for sure.
Jul 07, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
DVD Drive door stays open
>One solution is to TAKE A SMALL PIN AND RESET YOUR DRIVE BY POKING THE PIN INTO THE HOLE BELOW THE DOOR..
If this doesnt solve....
You need to necessarily replace the drive..
Jul 07, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
Epson Stylus Photo R300 Inkjet Printer When I try to print on a cd/dvd I line up the arrows hit print but it keeps telling me to close the cd/dvd tray, there is no way it will print with this tray.
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Feb 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Cd drawer opens and closes by itself
the sensor that tells it when door closes under door theres a guide that flips a slide switch as it goes in is failing. bad hardware!
Nov 11, 2008 | Philips PCRW (PCRW404) CD-RW Burner
SLIGING DOOR FOR SINGLE CD IS BROKEN
if the door opens and closes dvd player may be faulty
if the DVD tray wont open the disc is stuck inside try Turing it off by the power point wait 3 seconds then back on if disc still doesn't come out (YOU) may need to be remove manually which you need to take it apart
Jul 07, 2008 | Televison & Video
My writemaster DVD RW door wont close
try updating the drivers. if it will not work give me additional information
Jun 06, 2008 | Computers & Internet
The cd door is stuck - i cant open the door or close it, help? Tray does not open when switch is depressed. Green light burns steady.
http://video.about.com/pcsupport/Open-a-Stuck-Drive-on-Your-PC.htm
First, you'll need a paperclip. Unfold it so there is 1 to 2 inches that is straight.
Now, look closely at your drive door. There should be a very small pinhole either above or below it.
Insert the paperclip. There is a very small gear that when rotated, will manually open the drive door.
Retract and reinsert the paper clip as many times as it takes to eject the drive enough so you can hold onto it.
Pull Out the CD or DVD Drive.
Now slowly pull the drive out until it is fully retracted. Remove your stuck CD or DVD, and slowly push the drive bay back until the door is closed.
Apr 18, 2008 | TDK (DVD+RW47BXS5) Storage Media
DVD will not close its door
Open it up (take the screws out) and see if one of the door tracks came out. Just snap it back in place.
Jun 26, 2007 | Zenith DVB317 DVD Player
29 people viewed this question
Seeker5211
Seeker5211
