Question about InFocus Televison & Video
Infocus in74 projector model p740 had blown fuse on lamp driver board will i need new lamp and driver board?
  • 16 Answers
SOURCE: InFocus IN74 Projector Fault
Hi there.
How many hours had it done? The bulb may have expired and as a safety precaution the projector will not switch on, otherwise the bulb will explode causeing further damage.
Cheers
Posted on Feb 29, 2008
SOURCE: sony vpl cx5 no voltage to lamp
I downloaded the schematics and drawings for $US9.00 and found what I thought may have been a thermistor turned out to be a fuse. Obtained one from Sony spares and it is now OK. If it is possible would you guys know the value of the fuse [amp/milliamps??] If you are familar it is fuse 2P connected to C board, it looks like a small lump of plastic or diode block. The cost of the fuse is outragous from Sony. I hope I do not have to replace it again. However, if I do I would love the valua and I could see if I could get one from Radio shack or someplace similar. If I was not retired I would buy one and put it on a step tranny and watch the ampmeter for the blow current. But, thats life when you decide to retire. I believe the voltage value is 3volts??
Would appreciate any feed-back on the value of the fuse.
And I hope this may help others
Thanks and Good-day
Leckie
Posted on Mar 01, 2008
SOURCE: sanyo plc xu 40 lcd projector problem
hi i have a infocus lp720 with new lamp but there red and green images all around the outside of things what is it and can this be fixed cheaply? thanks john
Posted on Jul 18, 2008
  • 6 Answers
SOURCE: Infocus In24+ driver?
IN24 does not require a device driver it utilizes the video display drivers built into the Microsoft Windows OS. You should be able to simply connect the PC/Laptop source to the input VGA connector on the projector then project.
Make sure to toggle your PC/Laptop to output out of the VGA port otherwise it will not send data to the projector
Posted on Nov 19, 2008
projdoc
  • 2237 Answers
SOURCE: Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Posted on Sep 04, 2009
When I turn the projector on, it goes about 2 minutes, the picture (lamp) flickers and then it shuts down. I can pull the power cord and when I plug it back in, it will start up again but repeates the...
I also had the same problem and finally we heard some glass shattering sound. I opened the projector cover and found signs of burning and one part separated ?diode or what I do not know. I can see a small hole on the board possibly where the wire got broke and the piece became separated and resulted in a shattered noise, I suppose.
Dec 31, 2010 | InFocus Play Big IN76 Multimedia Projector
InFocus DL640 projector is not powering on. Lamp seems to be OK. I did not see any black spots or marks on the lamp. Wondering whether the PSU or fuse is blown. How do I check whether PSU or fuse is OK.
I had the same problem with my LP815 projector, it wouldn't power on the LED lights did do anything. I open up the projector and replaced the fuse, and now it works! Just replace the fuse and that should do it.
Oct 22, 2010 | InFocus Office Equipment & Supplies
My InFocus for the classroom won't even turn on. Absolutely nothing is turning on even though it is all plugged in correctly.
Either the power input board is bad,the fuse on the opwer supply/ballast is blown or the lamp door is not secure. This will have to be repaired by a tech if is either of the first two.
Oct 11, 2010 | InFocus ScreenPlay 4800 Multimedia...
Just stopped working. No LED. Changes the Lamp no fix! ANy clues
The first generation of the IN72 / IN74 / IN76 projectors had a power supply problem where a fuse on the P/S was under-rated. The 1amp fuse was subsequently replaced with a 2.5amp fuse to correct the problem. The reworked units have heat-shrink tubing over the fuses whereas the older 1amp fuses are bare. The fuse is located under the heatsink, about center of the board.
Feb 14, 2010 | InFocus Play Big IN76 Multimedia Projector
InFocus litePro won't turn on.
With a bit of luck a fuse may have blown though almost certainly the lamp has gone. Never **** the projector when the lamp is on.
Aug 28, 2009 | InFocus ScreenPlay 5700 Multimedia...
Hi there -- I have an infocus sp5000 project and i think the fuse has blown -- how can i replace it?
there is a fuse on the power supply, right on the power cord socket, but you need to remove the cover. but test this first: are there any leds on? if yes, it's not the fuse. check the lamp door and the filter cover on the bottom. it could also be the lamp is bad, the ballast is blown, the fans have stopped, the thermistor is blown, etc. if there are no leds, it could be that the power supply is bad. if you want to tackle this: remove the 4 bottom screws, then lift the top from the back, carefully remove the ribbon cable fron the main board (slide the cable locks on either side of the cable towards the front of the projector to unlock it first), unplug the wires in the front, and slide the lid forward over the lens. remove the main board off of the top (removing the 3 ribbon cables, all other wires, the cable nuts off of the back, and a few screws). the power supply is on the back side. if the power supply is bad, you can buy one from an infocus authorized service center (check the website).
Jul 17, 2009 | InFocus SP5000 Home Theater Projector,...
Doest function.no image projection,fun does not function
fuse on ac filter board. if that's ok, there is a power supply issue.
May 31, 2009 | InFocus PROJECTOR LAMP, Projector Lamp FOR...
Infocus projector power supply parts
you won't find schematics for them. infocus had their boards made by someone else who now no longer makes boards. it's usually the caps drying out that causes power problems.
Nov 03, 2008 | NEC VT670 Multimedia Projector
Televison & Video Logo
379 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
