Question about HP OfficeJet K80 All-In-One InkJet Printer
HP k80 will not print yellow
Hi Can anyone help. My printer will not print yellow or anything that needs yellow 9ie green,orange etc). The cartridge has been refilled. I have cleaned the nozzles, re aligned the cartridge, even installed a brand new cartridge. Nothing. Also cleaned the cartridge contacts and the contacts in the printer - both the colour and b&w. HELP before i chuck it out the window and resort to buying a new one. thanks Tony
  • wisenor Jan 10, 2008
    I have an hp photosmart 2610 that won't print yellow. I replaced the ink cartridge with a hp brand cartridge, cleaned the contacts, aligned the print cartridges. Still no yellow ink which means no red and all dark colors.. Any suggestions?
    President:
  • 3,130 Answers
Spounds like a defective print head bud. these do wear out and most of the time it will cost as much as a new unit.. Good Luck
Posted on May 21, 2006
Only printing Yellow
Sir/Madam
Please See The Vedio On Youtube
By This Time i Fixed My Problem,
HP 2500 color only prints yellow
or
Follow Us On
HP Printer Support
Jan 08, 2014 | HP LaserJet 2550n Printer
Only yellow is printing
Put the cartridge head in hot water for a minute, the ink may have clogged the print head.
Dec 05, 2017 | HP LaserJet 2550n Printer
Mac OS X Lion compatibility with HP officejet K80
Hi Li Louba,
Thats right,you cant print because there are no Hp K80 printer drivers support for your Operating System[Mac OS Lion] as yet.Check out your printers compatible Operating Systems here.
Hope this helps.Thanks!
Dec 05, 2011 | Computers & Internet
Print colour is off
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Aug 27, 2009 | HP Photosmart D5360 InkJet Printer
One page jammed after switching off when 1 page printed. Orange light on
Hi ,
First off all u switched off the printer and on switch off mode press the green button and on pressing the button switch on the printer hold that button for 5 seconds and then release the button whenever u realese the button the printer start migrating . After migrating if the printer have same problem then u reinstall the printer driver and again reinstall the driver, after reinstalling the driver the printer will working fine .
May 26, 2009 | HP LaserJet 1010 Printer
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
HP OfficeJet K80 All-In-One Problem: Constant Request To Realign Cartridge
This could be a hit or miss but what does it hurt to try...
I had this problem with the color cartridge a while back. Worked tirelessly with HP support and somehow got it to work. Since it was on the phone and a while back, I fogot! Now is the time for the black cartridge. Same thing. Reading somewhere here about skipping the test I gave it a try and it worked.
- Unplug the printer for 1 minute (not sure if this is necessary but it doesn't hurt).
- Replug.
- When the "Press Enter to align..." message comes up, PRESS and HOLD Enter.
- While holding Enter, press Menu. The screen skips the test part and shows the date.
- Release Enter. Now you can print. Actually, I could print, you are on your own now.
Aug 18, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Hp Deskjet 845C - Yellow Colour not Printing
I found this post to work for me when yellow was not printing on my HP PSC750 after using 2 cartridges: "Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge."
Jan 31, 2008 | HP DeskJet 845c Printer
Hp K80 printer
I cleaned the vertical centerpost (you'll see it when the cartidge is out)with a small amount of acetone (nail polish remover) on a Qtip & it works fine now....must be some kind of circuit that needs to be closed and the ink on it kept it open....
Dec 19, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
HP OfficeJet K80 All-In-One InkJet Printer Logo
295 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
