Question about Sharp DV-RW340U DVD Recorder/VCR
Trouble recording to DVD - connections are not done right - Sharp DVD-RW340
I cannot for the life of me figure out how to connect my Sharp DVD-RW 340 to my cable box and TV so that I can record shows to DVD. I tried to configure as per manual but it is not working. Can somebody tell what the easiest way is to get this to work. I am able to connect the raw coax cable line to the VCR and get unscrambled local channels but I want to record the scrambled channels.
Thanks,
I had to run from the RCA outs of my DVR into the inputs that are on the front right of the RW340...behind the little door.  Now I can easily record from live cable or from my Comcast DVR recorder.  Couldn't get it to work from the backside inputs.
Mine is just the DV RW340 (no U).  And yes, the manual is brutal.  We had to call tech support to find what disc will actually work in the darned thing.
Now my big problem is finding more 4x DV-R disks. Shoulda bought more when Comp USA was clearing them out a few years ago!
I have had great success with Dynex Model: DX-DVD-R25 discs.  And they play equally nicely on my Toshiba DVD player in the livingroom.   I have also given several away to people after I had transfered home videos to DVD and those people all had good results playing the discs that I made on my lowly Sharp Dv-RW340.
Posted on Dec 27, 2008
With my DVD-RW 340 can I watch a VCR tape while it is being recorded on a DVD? I can't figure it out.Thanks, Ron
I think the answer is NO, as consumer devices switches one at a time on the selector. Normally it's record from player to recorder and TV tuner to recorder. kindly check your manual as it varies from Brands/Make.
Dec 02, 2017 | Televison & Video
Snowy screen when I play a DVD
hi!!!!
try to change the cable!!!
may that helpS :)
Sep 27, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Owners manual for sharp dvd- rw/r recorder
Please send an email to LBrown18062@hotmail.com. Put the subject as "Sharp DVRW2U" I will send the manual to you right away.
Feb 04, 2012 | Sharp DV-RW2U DVD Recorder
I burned a dvd on my MAC book pro, but it won't play on Sharp dv-rw340 vhs/dvd combo. The disk plays on other machines, so I know it works. Any suggestions?
Hi there. I would suggest looking at your owners manual to see what formats are supported by your player. It may not support recorded dvds.
Mar 30, 2011 | Computers & Internet
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
I want to dub a vhs tape to dvd-rw but have lost my product manual- I have had a go once already and the dvd is set to the correct channel to record what is playing on the vcr but there is no data on the...
connect the red/white/yellow from the input on the dvd to the red/white/yellow on the vcr sellect av1 on the dvd recorder and you should be right and as a bit of help here is the manuel to your dvd recorder
it is written in pdf so if it does not open you will have to download adobe reader its free go to adobe.com
http://www.cyberscholar.com/sharp/resources/dvd_man_DVRW350U.pdf
May 15, 2010 | Sharp DV-RW340U DVD Recorder/VCR
Hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Nov 17, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
Error code E 4 54040990
jamesgranger - I think your DVD recorder is still having trouble reading the DVD+RW. It should not have a problem using a DVD+RW many times. Try taking the DVD+RW and put it in your computer. Find it in Explorer, right-click and choose "Erase". Then try to record to it using the DVD recorder again. If it works, you can use this to record, though it might be a pain.
The fact that your machine will record to the +R means that it works. Failing to work (record or erase) on the +RW means it's not reading it well. I would try running the lens cleaner again if it were mine. Also, I would make sure that the unit didn't have a lot of dust in it. If you can, power it off and use some spray-air to be sure there's no dust. You may have cleaned the lens, but if there's a lot of dust inside the unit, it will quickly find it's way back to the lens and you'll have the same problem. Michael
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
Sharp DV-RW340 Compatible Discs
I have had great success with Dynex Model DX-DVD-R25.  They are specifically: 4x  120min.  4.7gb. It's a spindle of 25.   The UPC Code is 00603 10116.  Now I'm searching for more myself!   These discs have worked well for me and play great in other DVD players, as well.  If you find 'em... please post it here!
Mar 25, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Sharp DV-RW340U DVD Recorder/VCR Logo
260 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
