Question about Oreck XL2600 Vacuum
Cleaned tube but no suction
The brush is turning fine and the tube is clear, but i am not getting any suction.
Thanks!
Chuck
    President:
  • 1,673 Answers
Then it is clogged in the inlet by the brush roll, or the fan has worn down too much.
Posted on Oct 03, 2008
Riccar 8995 no suction
If it's been over a year since you've replaced the belt that is the first place to start. Stretch belts lose elasticity and will still turn the brush roll but when the brush roll is lowered to the carpet it may not turn fast enough to pick up properly. If you have good suction at the end of the hose check to make sure there is not an obstruction in the tube where the hose goes into the bottom of the vacuum to the brush roll. Make sure your filters are replaced at least once per year and the bag is not full or has a lot of fine powder dust in it which can clog the bag.
Jun 13, 2014 | Riccar 8955 Upright Vacuum
When taking the handle/wand back to use it seems to lose the suction power regardless of what setting I use. Upon several times of standing it back up it seems to engage the suction power correctly is...
When you say taking handle back I assume you mean the action to start rotation of brushes. Had simular problem and found by removing brush from tube and then cleaning "baked on rubbish" in plastic tube (so you can see clearly through tube) Clean with stiff brush and also making sure brush drive belt housing is also clean and allows brush to rotate square to housing did improve the suction power.
I assume you have cleaned all filters by wahing under running water and applying a little pressure to remove water and attached dirt?
Nov 08, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
Mar 11, 2011 | Electrolux Vacuums
My dyson vacuum motor is sounding very high pitched... The tubes are all clear and there is suction with the tubes not not real good suction on the beater brush area....
Your dirt path is clogged, probably not far from the brush area. This is the reason you noticed the hi-pitch sound coming from the motor.
You may have to remove the hose to clear it.
Jan 19, 2010 | Vacuums
Suction in Wand Only, (No suction down below).
check the small hose that is under the machine ( it connects to where the brush roller is ) also you can remove a u shaped tube near the bottom of the machine and also another on the right side of the machine near the bottom as well
Sep 08, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Apr 28, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacume wont **** opened it up see nothing wrong HELP
If no suction usuallly means a clog, either in the hose and the dirt inlet by the brush roll. Sometimes if the belt is stretched, it won't turn the brush roll under load and it would seem like there is no suction.
Apr 19, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
No suction at floor brush. Plenty of suction in the tube that goes to the joint just before the 90 degree turn to go from the handle to the brush area.I lowered the handle so that the tube was straight and...
Are you sure the brush roll is turning. If not sometimes it will appear to not be sucking. Take off the bottom plate, then you can get to the brush roll and belt.
Oct 30, 2007 | Hoover 5416-900 WindTunnel Bagged Upright...
Oreck XL2600 Vacuum Logo
74 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
