Question about Philips (867093110009) Projector Lamp for ProScreen PXG1
Philips Rear Projection Model 55PP8620 - convergence problem
My 55PP8620 has just lost its colour convergence. I have tried to correct the colours both manually and with the inteligence system. A local TV technician says I may need to replace the convergence system. Are these still available in Australia or can I purchase elsewhere? I opened the back of the TV and found a 5cm square box mounted in the centre of the unit. This is marked 'Sony' and has the words 'screen' and 'focus' plus 6 small tuning knobs. The TV has had previous repairs - is the Sony part standard in this model Philips TV? Thank you for your support.
  • lukev Sep 15, 2008
    OOPS! Sorry guys - it's actually a SANYO part - not Sony.
    Anyone got any ideas?
  • john campise Sep 29, 2008
    ive got a philips 55 pp and the green is all but gone ang thepicture is "bent" in the corners.repair guy said $350.00 to fix>>>ouch.ive been an electrician for 20 years so im gonna try and fix it myself.im hoping to find a procedure of tuning.
  • Philips Master
  • 1,213 Answers
Manufactures sometimes contract with other tv companies to build their tv. Regardless of the internal hardware you still have a philips tv. I beleive this set was made by Hitachi. And what you are looking for is a replacement board. This board is referred to as the small signal module. When contacting a rebuilt board, have the model# and the chassis# available. And contact PTSELECTRONICS.com or Andrews Electronics.com. The board you seek is in the rear lefthand side on the floor of the TV. You will see a pair of tall aluminum fins. Theses are the heatsinks for the convergence ICs. I would definitely replace this small signal module, as repair on the local level will require pulling the board in and out of the tv several times. The company will give a part number and then you may order this. Striving for success the first time!!!!
Posted on Dec 25, 2009
  • matt martin
    matt martin Dec 25, 2009
    And if it is not too late to say...donot adjust the six control knobs you referred to!!!!
  • matt martin
    If it is not to late to say....do not adjust the six knobs you referred to!!!!!
Size of phillips 55pp8620 There is no picture and
Good day!!!!
I need to know first if your TV is on standby mode (red LED lit) or not?..If the green light lit your TV your high voltage (HV) is switch but you have open line on heater that cause of no picture and the sounds is chirping because of analog(antenna)/digital connection or bad audio chips..
I need this information above for specific diagnosis and to prevent more damage and failure..Also I need this information to avoid mistakes to buy a parts with no help...
also I need the model # because on my tread there are 2 model # which are correct? is it 60PP9202 60" or 55PP8620?..for specific diagnosis and for possible get a diagram..
Thank you very much for choosing my service!!!!
Rossiel Gomez (nineng)
Jan 20, 2012 | Philips 60PP9202 60" Rear Projection...
Philips rear projection TV component identification, what is it
They adjust FOCUS and Screen settings---they have nothing to do with convergence---if you have not touched them---do not---they are not real easy to reset correctly.
What is wrong with the set and what is the model number?
let me know and I will try to assist you
SD TECH
Oct 04, 2009 | Televison & Video
Colour convergence on a projection TV
hello it sound like convergance chips may be the problem
shaun
May 11, 2009 | Philips 43P8341 43" Rear Projection...
Colour misalignment and focus
You need a new convergence board. Not an easy fix, sorry.
Nov 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Philips Convergence for 55PP8620/79
Yes the box marked sanyo is the focus and screen control box. All stk Convergence ICs for rear projection TVs are made by Sanyo, which was the origional producer of the STK series Convergence IC. You need the convergence repair kit for the DPTV series rear projection which consist of two STK392-120 ICs and 11 6.8 ohm 1watt metal film resistors. You can get the repair kit for your model at the following link , they do ship to Austrailia however they do have an international shipping charge which must be purchased for orders outside the north American continent,. They also probide free installations instructions with pictures and free tech support. Heres the link.
http://servicemanuals.vstore.ca/
Sep 15, 2008 | Televison & Video
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
242 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
