Question about SanDisk Sansa e200 MP3 Player
SanDisk Sansa m200 series and my macbook pro
I was given the e200 mp3 and I have a macbook pro. I attached the player via usb cable to laptop and nothing comes up on desktop indicating player is available to have music from itunes moved to mp3. any suggestions?
  • SanDisk Master
  • 19,396 Answers
It is complicate,
it works on Mac OS only if you downgrade firmware for sandisk.
Here is how to do it.
If system crashes while you install the firmware you will damage the sansa, Mac OX is solid , but be careful with the USB cable.
Here is the procedure: How to use your SanDisk Sansa e200 Series .mp3 player with OS X ...
Here you can also download software
Posted on Sep 13, 2008
How to delete songs that are not showing
Try switching USB mode of the player, to see the hidden files.
See next help link:
http://kb.sandisk.com/app/answers/detail/a_id/447
Look in the manual for the m200 series players on page 31 under USB, how to select Auto Dectect (MTP or MSC) or only MSC :
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
MTP is Media Transfer Protocol, seeing the player as a media device.
MSC is Mass Storage Class, seeing the player as a removable disk.
All support for the m200 series players, on next page:
http://kb.sandisk.com/app/answers/detail/a_id/4487#m200
May 19, 2010 | SanDisk Sansa m240 MP3 Player
Player won't work with vista? can i download software to make it compatible with vista?
When you're able to view the menus of the player, look in the manual on page 30 = page 31 of the pdf file for the USB connection mode on your player:
Settings
USB > Auto Detect
> MSC
M200 series manual in pdf format:
With Windows Media Player 11 under Vista, the player should be
recognized as a media device in this Microsoft Media Player. Transfers can be made in MTP mode (Media Transfer Protocol) using WMP 11: USB mode should be in Auto Detect.
In Autodetect mode files on the player can also be viewed in the Explorer mode under My Computer, seeing the player as an external flash drive.
In WMP11 use Library and Sync mode for creating playlists and synchronizing music. More about how to use WMP11, see the help items in the player (click on e.g. Library or Sync etc.) or go to the Microsoft site:
http://www.microsoft.com/windows/windowsmedia/player/11/using.mspx
When USB mode is set to MSC mode (Mass Storage Class) the player can only be viewed in the Explorer under My Computer.
More online support for the Sandisk M230 under M200 series players.
Main main support link:
Update page for the players' firmware using the Sansa Firmware Updater:
http://kb.sandisk.com/app/answers/detail/a_id/1107/kw/updater/p/555%2C662%2C670%2C677/r_id/101834
Help links for the M200 series are also available on Sansa Forums:
http://forums.sandisk.com/sansa/board?board.id=m200
When needing more help from this side, don't hesitate to post another comment in this question.
Mar 22, 2010 | SanDisk Sansa m230 MP3 Player
Trying to add 4 GB microSDHC card to sandisk sansa e260. connect e260 to computer via USB. insert micro card. computer does not recognize microcard. why?
The player automatically connects to the computer in Media Transfer Protocol mode (MTP mode).
For accessing the microSD card in the player, the USB connection in the player has to be set to MSC mode, see:
http://kb.sandisk.com/app/answers/detail/a_id/167
How to change USB mode for the e200 series, proceed as next:
1. From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC.
Manuals for the e200 series:
version 1:
http://mp3support.sandisk.com/downloads/um/e200v1_userguide_en.pdf
version 2:
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
version R, Rhapsody:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Nov 21, 2009 | SanDisk Sansa e260 MP3 Player
How to download music from my computer to sandisk
To Sansa m200 series manual in pdf format with this link:
Use the provided USB cable for connection.
For transferring music to the player you can use the next software.
Windows Media Player; how to use WMP see:
http://kb.sandisk.com/app/answers/detail/a_id/389
Sep 30, 2009 | SanDisk Audio Players & Recorders
How do i free 8mb in Sandisk Sansa M250 i formated but the same result happens plz help me!!!!
SanDisk tech support recommends formatting the m200 series in both MSC and MTP modes to completely clear out all work areas,"fragments" and residual data. The m200 has a very basic Operating System that doesn't have a defrag option. According to tech support, the m200 needs formmating occasionally to keep it working smoothly. I learned that formatting will also clear up intermittent hang-ups. I format mine each time I reload it.
Format in MSC Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then MSC.
Connect the m200 to the PC via the USB cable
Right click on the "Start" button.
Left click on "Explore"
Find the m200. It will show as a hard drive, for example: "SANSA M250"
Right click on the m200 device and select "Format"
After formatting is complete, click on the "Safely Remove Hardware" icon on the System Tray and stop the device
Disconnect the m200 from the PC.
Format in MTP Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then Auto Detect.
Connect the m200 to the PC via the USB cable.
Find the m200. This time it will not show as a hard drive but as a music device, for example: "SanDisk Sansa m250"Note there is no drive letter in MTP mode.
After formatting is complete, disconnect the m200 from the PC. There is no icon to stop the device.
Your m200 device is now formatted and ready to reload.
By the way, MSC mode is mostly for use with other than Windows XP computers. If you are using WinXP and Windows Media Player 10, you might consider using MTP mode and WMP to manage the m200's.
Source: http://forums.sandisk.com
If i was helpful, kindly do Rate!
Regards.
Jul 28, 2009 | SanDisk Sansa m240 MP3 Player
Playlist not working
firmware might be damaged
May 16, 2009 | SanDisk Sansa e200 MP3 Player
I have a SanDisk Sansa m200 mp3 and a macbook pro
Even on a Macbook pro, you should be able to access your "my computer" option, where it shows you the local disk drives and everything. your mp3 player icon should appear there. then after you click on the icon it should bring up a page containing folders "on" your mp3 player. there doesnt have to be any music or videos or anything like that to have the folders already on there. now i dont have a mac but what i suggested you to do should work.
Sep 14, 2008 | SanDisk Sansa e200 MP3 Player
Connection problem
its the usb connection you probably connected to hub with bad usb port or needed update usb parameter port
Apr 11, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Integrating sandisk 200 with mediafly
Hi, try the latest mediafly syncclient at www.mediafly.com/syncclient and also make sure that youre 3200 series sansa is in MTP mode (settings > USB Mode).
Best.
Apr 01, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
416 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
