Question about E-Machines eMachines Desktop PC
E MACHINE 390
I SWITHCED ON THE MACHINE YESTERDAY. IT ATTEMPTED TO START UP. NORMAL START UP NOISES HAPPENED FOR 15 SECONDS OR SO THEN IT SORT OF MADE A CLUNK CLUNK SOUND, BEFORE ATTEMPTING TO RE BOOT AGAIN.
THE SCREEN SAID OPERATING SYSTEM NOT FOUND.
I SWITCHED OFF AT POWER SOUCRE, WAITED A WHILE AND THEN TRIED AGAIN. SAME RESULT.
WHAT IS THE PROBLEM ?
    Scholar:
  • 172 Answers
Check CMOS is finding hard drive at POST (power on self test) if present then is the boot sequence set correctly. Is cpu fan running, is hdd and cd/dvd devices running? Is there a display on screen, if yes what does it say ?
Check ribbon cable to hdd from motherboard is good, replace with a known good one and try booting again. Come back with results, for more support.
Posted on Sep 15, 2008
I had a simaler prob i had a lose connection so make sur all the wires are in properly if you have no lucktake it to a comp shop
Glass Window Shattered During Wash
Maybe the internal drum was rocking due to an unbalance with the weight of the towels that it has knocked onto the door causing the glass to break. only thing i can think of , glass shouldn't break unless its hit or there is a large amount of temperature change, adding cold water to a hot glass for instance.
Mar 24, 2014 | Bosch WFVC3300 Washer
Washing Machine will not start
either your door actuator is broken or the door switch itself. look at the door and see if the latch(actuator) is broken or loose. If not order a door switch. It can be changed easy if you remove the retainer from the bellows and loosen it from the front of machine.
Hope that helps
Nov 26, 2013 | Washing Machines
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
Intermittent rattling noise in refrigerator
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Jun 27, 2009 | GE Monogram Refrigerator Built-In...
New to expresso machine - Cuisinart EM100c
This is a very loud machine. Here's the normal operation: You turn it on, and wait a few minutes for it to heat up, at which point the heating light will go off. Then make sure the function knob is turned to coffee, and it will start brewing. At first, it will make a short (loud) sound and then stop for a second. The purpose behind this is that the machine is pre-wetting the coffee, so that steam can more easily shoot through it in a couple of seconds. Then the loud noise will start again and run continuously until you turn the function knob back to the center. So, the sounds you were hearing were normal. There is a delay between when you hear the sounds and the water starts flowing out. If the coffee is pressed down (tamped) too hard, that delay will be longer. Hope this helps. You made a much better choice purchasing this machine rather than the more expensive EM-200, in my opinion.
May 10, 2009 | Cuisinart EM-200 Espresso Machine
Electric Kenmore Dryer runs short time (seconds) and then stops.
your thermostat/s are not doing their jobs. They are allowing your dryer to overheat and also if your dryer has not been cleaned out on the interior you might want to do that. I've taken out globbs of lint build-up in them.
Mar 25, 2009 | Dryers
Banging noise in my refregeeratio
check the seal around frezeer make sure no air is escaping
Nov 19, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Zanussi fx1465W not working
the machine should make humming noise,before it takes in water check water feed to machine get back if you cant sort it
Nov 28, 2007 | Washing Machines
HP 1040 Fax machine
Most likely the telephone line seems to have nise/disturbances and the machine must be getting communication errors.
Please get the phone line checked  from tel company
happy faxing
omnipresent
Oct 16, 2007 | HP 1040 Plain Paper Inkjet Fax
E-Machines eMachines Desktop PC Logo
148 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
