Question about Minolta EP4000/5000 CS/PRO Copier
How to clear EP 4000/5000 memory - Minolta EP4000/5000 CS/PRO Copier
    Problem Solver:
How can resolve paper is not giving cs pro 5000 manlta photostat
Posted on Oct 02, 2011
  • Minolta Expert
  • 1,326 Answers
Very easly, When you open the front door of the copier look above the fixing unit on the inside cover. You will see the display adjustment knob. There is one screw that holds it in. Remove the cover and you will see a PCB. It has two gold post on it and a black trouble botton and in between the two gold post is a silver dot. Its a common ground. The question is what do you want to clear???? The meter or the whole copier? Get a paper clip a small thin one and bend it soo you can jump, one gold post and the common ground. Turn the copier Off, then make sure you have the pin and ground connected, and turn the copier ON. The display should display" Do you want to continue" or some thing like that. Hit yes and unjump the post and ground and close the front door and it should boot back up. You also may have to cheat the front door to show that it is closed.. Good Luck... The only draw back is that info was stored on your RAM pack and you copier will be reset to factory settings or un-useable setting. You will have to reset all the common settings manually. If you have a problem with the copier you may want to try another RAM pack first..
Posted on Sep 15, 2008
What do the letters EP stand for on the dash board of the mini cooper 2003 model?
EP means "emergency program" - this means there is a fault with the transmission. This can be a simple sensor issue, a need for calibration or teach in, bad alternator/battery, old fluid, total transmission failuire, etc, etc, etc.
The fault memory needs to be read out to determine exactly what is putting the car into EP.
EP is essentailly the transmission warning light.
Apr 11, 2016 | Mini Cars & Trucks
What is ram pack and where is this in minolta copier 6001
The EP 6001 is not a digital machine. It is analog. As for RAM there is a memory for the counters on the screen but some one can clear it lucky there is the hard counter. What is the issue with this machine?
Nov 20, 2015 | Minolta Office Equipment & Supplies
What does error code EP
you should be able to clear the code by removing the battery, and by the way does it have new good batteries?
Nov 17, 2015 | Walgreens By HoMedics Automatic Wrist...
How to reset epson t 60 printer
Depends on what you mean by "reset".
If you're referring to the waste ink counters, you can either:
  1. Locate a copy of the AdjProg service utility and use that to reset the waste counters
    Note: Will not work on MacOS or Windows 8
    ... or...
  2. Download the WICReset (for windows) or iWIC (for MacOS) and purchase a WICReset key to reset the waste ink counter that way.
Whatever you do, remember that resetting doesn't deal with the waste ink inside the pads so you should be looking at changing the pads (not easy to do yourself) or fitting an external waste ink tank like a printer potty.
Aug 06, 2013 | Epson Stylus Office Equipment & Supplies
Lowrance EP-85R storage device data lost
how much memory space do you have on your chip if you use up all memory it will delete all to make room for new memory
Jan 19, 2013 | Lowrance Boating
Hi I have a mother board EP-4T2A3 and it supports
This EP-4T2A3 is unique, that the can only utilize the slightly more expensive RDRAM memory modules. Furthermore, because of the dual memory controllers in the i850 chip-set, all motherboards based off of this chip-set must also have its RDRAM installed in pairs. You can purchase RAMBUS chips of PC600 to PC800 memory modules. You have 4 RIMM slots, and they must be installed in pairs, or you will get speeds of only a single module. The unfortunate part is that the RDRAM modules are a little more pricey. You can find some samples of these HERE.
Good Luck
Mark
Dec 29, 2009 | EPoX EP-4T2A3 Motherboard
How do I clear the memory for the Lexmark c510 printer when I receive a memory full warning?
This is from the service manual, unfortunately there isn't a cold reset, you can perform an EP factory reset in the diagnostic mode, but this won't cure your problem. Investing in some more memory is the best answer
Press Go to clear message
and continue printing job. Job
may not print correctly.
Press Menu to open Job Menu
and cancel current job.
To avoid this error in future:
• Simplify print job by
reducing amount of text or
graphics on a page and
deleting unnecessary
downloaded fonts or
macros.
• Install additional printer
memory.
Apr 15, 2009 | Lexmark C510 Laser Printer
My ep-8khal motherboard wont turn on!
first turn off your pc, open the right side panel of your pc and locate the memory card. after locating, pull it out and clean it with a pencil eraser, if you have separate motherboard, clean it also. and then turn your computer on, if the problem goes again, the faulty part might be your computer memory or the separate video card, if you have one.
Note: if you cant' do one of these tips.just have your computer repair by a professional comp. technician.
Jan 15, 2009 | EPoX EP-8K7A Motherboard
182 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
