Question about Sanyo Microwave Ovens
I have a sanyo emc1900 commercial microwave. Yesterday the 10 amp top circuit fuse blew for apparantly no reason, no visible signs of any other damage. I replaced the fuse and the microwave tested fine. It was used throughout the day yesterday, but upon first use today there was a smell of burning and a little smoke. not opened the case again yet but any possible solutions would be appreciated, I'm thinking probably high voltage transformer failed or failing?
  • Sanyo Master
  • 9,086 Answers
It may be a shorted or failing high voltage rectifier diode or high voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
You can find Sanyo UK microwave owner's manuals here.
You can find Sanyo UK support, parts and authorized servicers here.
Posted on Sep 16, 2008
Why does ge microwave blows fuse when door is opened?
Inspect the door switches and the wiring in the light bulb circuit. If the problem is a door switch, it will probably be visibly broken, or there will be burn marks on it. It's also possible that the door switch bracket is bent or broken and allows the terminals to short to the oven frame. Check the lamp socket - if it is cracked or burned, it should be replaced.
Also look for signs of arcing or burn marks on the controller board, especially near the relays (usually black plastic boxes about 1" x 1' x 3/4' mounted near the wire terminals or wire harness connector).
As a general note, it is rare for a fuse to fail by itself. If you find a blown fuse, look for a cause before replacing it. This may prevent wasting another fuse.
Jul 01, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave blows fuses
A short likely in the wiring for the light or at the safety switch embedded on the side where the door closes----be careful as a 20 amp fuse takes something major to take out.
(for it to blow)
This might be best left to a qualified service person.
Dec 22, 2012 | Microwave Ovens
Whirlpool Microwave MH6700xW-0 Blows internal fuses regulary
Assuming your power line voltage is okay, it would not surprise me that after 27 years, your high voltage capacitor is drying out and increasing its capacitance. This will cause variance in the high voltage output, which can stress the magnetron and increase current consumption.
You can order Whirlpool parts my model number here.
http://tinyurl.com/gv383
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Whirlpool Microwave Ovens
My jmc7000 jenn-air blew a circuit breaker. No power to the unit. There is power to the recepticle. I'm wondering if it blew a circuit breaker, does that mean the problem is most likely a big problem...
Yau say a few conflicting things. First you wonder if it blew a breaker, and then say you have power to the receptacle. If you have poer to your receptacle your breaker if not tripped. There are NO breakers Inside of the Microwave. Only 1 time fuses. So, if your init is dead it has probably blown a fuse inside of the unit. If that is the case. Probably shorted HIgh volt capacitor would be my first guess. If it is jsut dead. it can be other things than just a blown fuse. bad thermal protectors, bad low voltage transformer on main circuit board. Burnt wires. Anything that will cause it to lose power inside the unit. From bad parts to bad connections.
Aug 16, 2017 | Jenn-Air JMC7000 Microwave Oven
We have a GE Microwave 1440 and the fuse keeps blowing. It blew at the beginning of December and we changed it, it then blew again 3 weeks later and we changed it again. Then just yesterday it blew again...
Each time that it has blown can you remember if you had it set for a higher time? Reason I ask is, it can be any of the components inside that overheats after running for longer periods and the fuse is the part that will (or should fail) if the system overheats. If it's blowing that much, I can tell you it will be better to purchase a new one considering some of the components in a microwave is about $200 each and if the board is bad it's just as high. I say buy a new one and therefore you will have a warranty. We bought a home 3 years ago that came with the same microwave and it lasted about 1 year, and having the same issues. Good Luck.
Jan 03, 2011 | GE JVM1440 Microwave Oven
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Blue sparks from my panasonic over the range microwave
We have blown four... yes 4 over the range microwaves from Panasonic. Are we the only ones having this problem?
Dec 20, 2008 | Frigidaire FMV145K Microwave Oven
I have a Sanyo microwave bought at Chatham Coop some time ago. Unfortunely for Roller Rest caught fire for no apparent reason and I wish to replace it. Product No. EM-S1067S UK 2. Please advise me.
i don't think you will be able to get this part any more as sanyo microwaves are not made anymore and the parts have been shipped of to awi in the isle of white so if anybody will have any bits it will be them,hope this helps
Jul 31, 2008 | Sanyo Microwave Ovens
Belling Microwave Problem
Apparently this one has a mechanical timer. That lack of electronic controls does lessen the complexity. I don't know about the specific regulations concerning British / EU microwaves, but I'm sure there's a fuse inside. In most cases, just replacing a blown fuse will not be the cure, unless one finds the reason it blew. What made it fail (if it did) is the real question. Loose fuse holder allowed excess heat? Shorted component or wiring? Or, is there a failure in the mechanical timer that's causing an open circuit connection? That can certainly happen. Also, a door switch may have failed. This is most commonly caused by opening the door while it's cooking, instead of turning the oven off first. I would suggest you contact Belling service: http://www.belling.co.uk//CMPage.aspx?pageid=130&subsectionid=85§ion=ContactBelling Good luck.
Oct 11, 2006 | Belling BIM60 Microwave Oven
Microwave Ovens Logo
348 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
