Question about Microsoft Office Professional 2007 Full Version for PC
Reboot of windows xp
When I try to install windows xp , the program runs up to the point where I'm asked to press f8 to accept the agreement , when I press f8 my computer does not respond and does not allow me to accept the agreement
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 110 Answers
Thats problem of keyboard please use other symple keyboard not multimedia
Posted on Sep 15, 2008
BLUE SCREEN
Which Operating System? You'll need a system disk to run the chkdsk command for a Dos Prompt (black screen with white lettering).
Insert the Operating System Disk in the cd drive, reboot from the operating system disk and select the option to Repair. It will search for your operating system and once found you will select it by entering a 1 for windows. Then it will ask for the Administrator's password which in most cases is blank so just press enter. When you see the Dos Prompt simply enter the command: chkdsk /r
Check disk will run well over an hour and you will notice the percentage of completion going from high to low, but that's normal. Let it run to completion then reboot the machine.
If you still have issues, then you'll need to reinstall windows. Try doing a Repair Install which preserves your music, pictures, documents, data and videos.
Windows XP Repair Install:
Insert the Operating System Disc in the cd drive and boot from it.
When the Options come up select the Option to Install Windows (Don't select Repair). It will start loading windows files and at some point it will ask you to accept the License Agreement by hitting F8. On the next screen after hitting F8 it will begin searching your system for an already installed operating system. It should find yours and give you more options to which you want to select the option to Repair. This will preserve everything you have on the system.
In windows vista to get to the dos prompt you will need to use the operating system disk and boot to it. Then get into the Recovery Console and look down at the bottom for the Dos Command Prompt or Repair option.
Mar 22, 2012 | Intel Computers & Internet
Crash windows xp
If the crash happens constantly you'll need a windows xp operating system disk then insert it into the CD Drive, click to Install and after you press F8 to accept the license agreement the system will search for any already existing windows xp operating sytems that are installed. If it finds your select R to repair the current operating system, this will preserve your documents, music, pictures, videos and programs.
Mar 14, 2012 | Computers & Internet
I get a blue screen and i cant log into my laptop
If starting windows on safe mode does not work you can try to repair by recovery console. But first you need to have a Windows XP CD, then follow this instructions:
1.Reboot the computer with the Windows XP CD in the optical drive. First you will need to accept the license agreement, press F8 to accept it and proceed.
2.Setup will search for existing windows installations, at this point it should give you the options to install a fresh copy of windows or to repair. In this case press R key to rapair.
3.After you press the R key, the recovery console should start up. It should show a message like ''Microsoft Windows XP Recovery Console'' etc etc. and command prompt. It will ask you wich Windows XP installation you would like to log onto, you should type 1 and press enter, then it will ask you for the administrator password, type it and press enter.
Now, don't really know what is your problem exactly, so lets try this:
4. Type ''fixmbr'' and press enter, this fix the master boot record.
Type ''copy d:\i386\ntldr'' and press enter.
Type ''copy d:\i386\ntdetect.com
5. Now lets rebuild the boot.ini, in case that it's gone or corrupted.
Type ''bootcfg /rebuild''.
Recovery console will try to locate all installed copies of windows and ask if you want to add them to the new BOOT.INI file that it's going to create, chose yes for the ones you want.
6.That's it. Type exit, and take out the CD from the optical drive.
If that does not work try checking the hard drive. Do this by entering recovery console as before. As soon as you get to the command prompt type ''chkdsk'' this runs the check disk utility, and will tell you if your disk is good or damaged. If it's damaged you will need to replace it.
Feb 06, 2011 | HP Compaq nx9020 Notebook
Hve a compaq presario laptop installed win 7 but now doesnt respond ,want to install xp plz help
XP is obsolete and unless you have SP3, there are no drivers from Microsoft.
Go to hp.com and download the Win7 drivers. That will fix your problem, if they are available for your model.
Jan 28, 2011 | Computers & Internet
How to repair Windo XP Pro. SP-3. Midea Plaire is also not working.
Hi Good day!!! Here are some ways to repair your winXP
Repair Windows XP Files with System Restore
1. Save your work and close all open programs. Click Start, then Control Panel, then Performance and Maintenance. On the left side of the screen, click "System Restore."
2. Select "Restore my computer to an earlier time." Click Next.
3. Click a date with a bolded number in the calendar on the left. Make sure this date is at least 1 day in the past. On the right side of the window, select a restore point. Click "Next" twice to restore your system.
Repair Windows XP Files With the Installation CD
1. Back up all of your user files onto removable media such as CDs or DVDs. Find your Windows XP installation or recovery CD, and insert it into the optical drive that your computer can boot from. Click Start, then Turn Off Computer, then Restart to reboot your computer. When the "Press any key to boot from CD" message appears, press a key on your keyboard. Press "Enter" to start Windows XP setup, and press F8 to accept the licensing agreement.
2. Select the path of your Windows installation and press "R" to begin repairing it.
3. Follow the instructions provided by the Windows XP repair program and finish the reinstallation. Go to the Microsoft website and download Service Pack 2 from their website, then visit Windows Update to install Windows XP Service Pack 3, critical updates and Internet Explorer 7.
Thank you for using FixYa
Don't forget to vote thanks!!
Nov 05, 2010 | Computers & Internet
Windows wont load
If the windows wont load then it is corrupted.
If you have a Windows CD Installer then run this and repair the operating system.
In order to run your cd installer, you will need to set on the cmos that cd rom is the first booting device.
Reboot your pc and hit any key to run the windows setup.. When prompted, press F8 to accept the agreement.
On the process of selecting previous windows operating system... select repair by pressing "R"
then continue the setup. You will also be asked to input serial key so be prepared to have it.
Good luck
Much appreciated if you could rate this help...thanks!!
May 20, 2010 | Gateway Solo 9550 Notebook
I am trying to format my virus rdden computer, however when I get to the point of accepting the agreement with windows (after booting from the cd) it won't allow me to accept. what do I do?
Generally this occurs when F12 is pressed multiple times causing the keyboard to stop responding because the keyboard buffer is full.
At boot, when the Dell Splash Screen Appears press the F12 key once when the progress bar is 70% across the screen (System should beep ONCE) then select the optical drive and press spacebar when prompted. The keyboard should work fine after that.
Feb 25, 2010 | Microsoft Windows XP Home Edition
Toshiba Satellite 1115 S103 can't install Windows XP home edition
after it reboots it will ask you to boot from cd,
ignore this and let it boot from harddrive, where it has already copied the files to... it should setup ok from there
Apr 06, 2009 | Toshiba Satellite 1115-S103 Notebook
Os keep restarting. on boothing the laptop, the windows starts and the user interface loads. when ask for username and password, on entering the username and password, the laptop restarts.
From my point of view I think the Operating system needs to be Repaired and below is a guide on how to repair
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press ENTER to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R", (you DO NOT want to load Recovery Console). I repeat, DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read WARNINNG #2
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. After the installation is over the system will reboot.
Enjoy
If This Solution has Worked Please RATE ME!!!!!!!!!!!!!!!!!!!!
Oct 22, 2008 | HP Compaq Presario 2200 Notebook
I have a Gateway Desktop PC.(831GM) I used Internet Explorer as my browser and now I can't access it. My ISP is Verizon and they tried to re-set my computer to the original default settings but we still...
You may need to put your model number in gateways website and download the drivers to a thumb drive or burn to a cd before attempting this.
The fastest resolution to this problem is to take a respective windows disk (make sure you check your key on the side of the tower and see if it says xp home or xp professional) whichever you have get a windows disk the same as this and boot from the windows disk first it will ask you if you want to boot from cd press any key do so. then it will load drivers. it will then ask you if you want to load the recovery console or if you want to install windows, press what key it says for installing windows. it will then check for previous versions of windows xp on the computer. eventually it will pop-up with a license agreement, press F8 to accept. then if you used the appropriate disc (XP or PRO) it will then ask if you want to repair the previous installation of windows. press r for repair. it will then begin the repair copying files then rebooting. do not remove the disc and do not hit a key when it asks if you want to boot from the cd rom at this point. it will do it's thing for about 2-5 minutes. at this point it will ask for a license key which you will type in from your key located on the outside of the case. hit enter it will continue, if it has a question about network settings tell it to use defualt. if any other pop-ups appear between now and reboot cancel the pop-up. it will reboot and again do not boot from the cd let it time out, and done you will be in windows xp. install all drivers needed and run automatic updates if auto updates do not work google: automatic update repair batch file. there are a few out there that will auto clear the cache for updates. after running it for a while and a couple more reboots then updates will function properly.
Jul 02, 2008 | Gateway Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
