Question about Xerox WorkCentre 490CX All-In-One InkJet Printer
Problem with DeIsL.isu that kills the printer
My printer will not print, won't even respond. Tried uninstalling inorder to reinstall, but the computer won't have that either. Tells me it can't communicate with DeIsL.isu . What do I do? Thanks
0 characters
1 Points
Dell printer will not complete task. If printer is uninstalled then reinstalled it will print one time but doesn't complete the task on the "printing screen". I go to the printer window...
Hi Bill,
Have you tried the printers on another PC?Please do.
  • Whats the Operating System on your PC?Do the printer drivers correspond with that Operating System?If not,download the corresponding drivers from this dell support site. This you select under compatibility.
  • After uninstalling the printer,disconnect fully and unplug from power.Reboot your PC before installing the printer again.
Hope this helps.Thanks!
Nov 01, 2011 | Dell V305w All-In-One R840635AU InkJet...
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
Epson FX-2190 keeps on printing unknown characters
The print que on your computer may still be trying to send processes to the printer. Even if you uninstall and reinstall the printer it can be reloaded on the same port as before. Open your print que and see if anything is pending. Hope this helps.
Aug 20, 2009 | Epson FX-2190 9 PIN Matrix Printer
"Printer not responding" message when printing test page
Have you tried deleting and re-installing the driver? And what kind of machine are we speaking of?
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Blank page
Hello, hope i can help. Glad you tried all these things. Sorry they did not help. Is the printer set as the defaukt printer in your settings. Sometimes this can be the isue. You should have an icon for your printer in my computer. Right click on it and go to properties. Is the printer set to work offline?? This can affect printing too. If this does not help, you need to check if it is installed correctly by going to control panel, selecting system, then hardware, then device manager for printer and scroll down list and make sure it says it is working correctly, with no exclamation marks or errors. If you find some, you need a new driver from lexmark website. If no errors, we need to look at further issues then. Good luck, post back if not resolved please. Cheers lilacgerry
Oct 27, 2008 | Lexmark X6170 All-In-One InkJet Printer
Fine one day, gone the next!
check for viruses first, then try by reinstalling the drivers, if not solved go to device manager and check for usb printing support in usb , if you can see just uninstall it and reinstall the drivers for the printer, if still you have the same problem then try with another usb,
post back your findings
May 30, 2008 | HP DeskJet 5550 InkJet Printer
Xerox WorkCentre 490CX All-In-One InkJet Printer Logo
75 people viewed this question
Top Xerox Printers & Copiers Experts
Level 1 Expert
Patrick Carmichael...
Are you a Xerox Printer and Copier Expert? Answer questions, earn points and help others
