Question about Kenmore 63942 Dryer
Install 220 outlet for electric dryer or trade it for gas dryer?
Just moved, new house (rental) uses gas but I have a Kenmore electric dryer.  Should I install/have installed the 4-prong assembly my dryer needs or trade the dryer on craigs list for a gas dryer?
  • 7 more comments
  • jersey pam Sep 13, 2008
    The landlord's cool with whatever I want to do.  Electricians are giving me the 'oh, around $250' response which usually means $400 once they are in the house.  My local Home Depot csr has showed me how to do it and it really doesn't seem that hard!  Parts would run less than $50.  I agree with you that I could be giving up my great dryer for something that will break in two minutes AND I'm risking putting in time and effort trying to DIY only to have it blow out the lights in the house!  And then there's the question of how to hook up the gas dryer...still need a service tech, no?
  • jersey pam Sep 18, 2008
    So... I hired the electrician to install the 4-prong plug for the electric dryer I already had.  $125.  I learned something interesting along the way that I'd like to share...  Once the whole installation was done, he found that he had brought the wrong outlet...the prongs didn't match up.  He went to the supply house and came back with a new cable for the dryer, which took two seconds to install!  That this was possible was very interesting to me b/c I didn't use this dryer in the last house b/c the outlet was 3-prong!  I could have just changed the cable on the dryer...for about $20.
  • Anonymous Oct 28, 2008
    Pam, i'm having the same issue with my apartment can you tell me what electrian you used. Thank you
  • sheilabob10 Jan 02, 2009
    need to install 240v onto 220v cord but dryer already has ground wire and i need to get it off how, switching from 3 prong to 4
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Yup. Only a licensed gas service company is authorized to actually make the physical connection to the dryer and tank and make sure it is not leaking. The reason being is that if you do not tighten the gas connection correctly, do not leak test and/or misadjust the regulator, you may have potential problems.
    Installing an outlet and running the correct wire to the service panel is not that difficult. It's not rocket science, after all. You need to ensure, however, that you use the proper gauge wire to handle the load requirments, and that you have sufficient service from the panel that can accomodate a 30-35 amp breaker. You can save money by installing the outlet and running the wire to the panel. But, a licensed electrician is the only one authorized to make the physical connection the service panel. You may question an electrician to see if they could cut some of the costs if you performed some of the install yourself. Just a thought...:o)
  • Jeff Rockwell
    If you are renting the place, you may want to run this by the landlord, first, before you start installing or modifying anything (if you haven't done so already). Installing a 220 service may be more cost effective, however. But...if you are not licensed in this field, it is a requirement for a certified electrician to install the service. An electric dryer requires its own dedicated breaker. Which means, you will have to run a separate line all the way back to the service panel and install a breaker of sufficient rating (usually 30-35 amps). I would recommend getting estimates for how much this would cost you, then compare it to how much it would cost to purchase a used dryer as you mentioned. Buyer beware, though, when it comes to buying anything used. Especially if you don't know the history of the appliance.
  • et n Aug 22, 2013
    here's a general price sheet, i'm an a electrician this is the average cost.
  • et n Aug 22, 2013
    here's a general cost chart, i'm an a electrician.
  • et n Aug 22, 2013
    Add a Comment1. Initial Service / Work Set Up / Travel $ 75.00 2. Switches - (single pole, standard toggle) Each Switch Added $ 75.00 3. Switches - (3-way or 4-way, standard toggle) Each $ 85.00 4. Switches Converted - from "single operation" to "3-way system" Each $ 105.00 5. Switches Replaced - replacement of an existing switch (3-way or decora add $5) Each $22.00 6. Switch Bank Expansion - (existing switch or switches converted to multi-gang) $55.00 ea. 7. Receptacles, standard Each $ 75.00 8. Receptacles, G.F.I.- (exterior receptacles add $25.00) Each $ 95.00 9. Receptacles, Quad - with standard devices Each $ 100.00 10. Receptacles DEDICATED CIRCUIT - 20 amp (with standard devices) Each $ 110.00 11. Receptacles Replaced - replacement of an existing standard receptacle Each $22.00 12. Receptacles Replaced - replacement of an existing receptacle to a G.F.I. receptacle Each $48.00 13. Special Cuts Made - for switches/receptacles in cabinet, paneling, tile, etc. (approx.) Each $65.00 14. Switch & Receptacle Wall Plates - (single gang, maxi, medal, ivory, or white) Each $4.50 15. RELOCATIONS relocation of a switch, light, telephone, cable outlet, etc. (approx.) Each $ 85.00 16. REQUIRED WIRING SPLICES accessible junction box(15 or 20 amp) Each $ 75.00 17. Lighting Fixture Outlet - (rough-in only & with wiring access) Each $ 75.00 18. Lighting Fixture Installation - (surface type no assembly required) Each $ 60.00 19. Lighting Fixture Installation - (with .5 hrs of assembly required) Each $ 70.00 20. Power Supply Circuits, Appliance Circuits - ( 15A & 20A ) Each $ 105.00 21. Appliances - connections only each $30.00 22. Power Supply Circuits, Heavy Circuits -( 30A & 50A ) Each $210.00 23. Ceiling Fan Installation - assembled and installed to an existing outlet Each $ 90.00 24. Ceiling Fan Installation - with existing outlet box replaced for proper support, Each $135.00 25. Ceiling Fan Installation - assembled and installed with new wiring and box outlet, Each $205.00 26. Ceiling Fan Accessories -extension rod, light fixture, wall control, etc. Additional $ 26.00 27. Recessed Fixtures - (standard size, open ceiling, trim and lamp not included) Each $128.00 28. Recessed Fixtures - (non-standard size - open ceiling, trim and lamp not included) Each $155.00 29. Under Cabinet Fixtures -(slimline fluorescents 12", 18" or 24") Each $128.00 30. 4FT Fluorescent Fixtures - (with Wrap-Around covers) $135.00 31. 2X4 Fluorescent Fixture -includes fixture, lamps & wiring (2x2 add $20.00) Each $ 108.00 32. 2X4 Fluorescent Fixture -parabolic with electronic ballast (2x2 add $25.00) Each $160.00 33. 2X4 Fluorescent Fixture - relocated & reconnected to the same circuit Each $50.00 34. Exit Sign - L.E.D. with battery back up (with wiring access) Each $158.00 35. Emergency Lighting Unit - 12 volt, wattage power for up to 5 remote heads Each $185.00 36. Emergency Lighting Remote Heads - powered from emergency lighting unit Each $ 85.00 37. Restroom Vent Fan - 80 CFM (ductwork not included) Each $145.00 38. Telephone Outlet - Cat-5 (no Jack Included) Each $ 85.00 39. Cable Outlet (No Splitters or Jacks Included) Each $ 105.00 40. Circuit Breakers - added to existing panel, interchangeable type. Each $ 28.00 41. Circuit Breakers - Arc Fault added to existing panel. Each $ 108.00 42. Power Pole - includes pole, 1-120 volt circuit and installation Each $220.00 43. Electrical Demolition - includes all work in dealing with the existing wiring Per Hour $75.00 44. SUB- 12 circuit panel with 60amp sub-feeder Each $680.00 45. New Service Upgrade SEE OUR WEB PAGE 46. Special Electrical Installations not listed above PER HOUR (see Special Notes below) $75.00 47. Permit & Inspection Fees approx. (License Fee Not Included) $175.00 48. Smoke Detectors - 120V. interconnected with battery back-up Each $205.00 49. Electrical Trouble-Shooting, Circuit Diagnostics - $85.00 per hour.
I have gas dryer need trade for electric one.
In michigan
Posted on Dec 15, 2012
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Thanks for all the input!  We reached a compromise in hiring an electrician who was willing to come out today and install the connection for half what everyone else quoted...on a Sunday!  The laundry piling up in the corner was very persuasive in convincing us that your advice (in the end, we'd need a professional no matter which way we went) was prudent.  Thanks. jersey p
Posted on Sep 14, 2008
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
SOURCE: need to install a 4-wire/ prong dryer cord strain relief assbly
The green wire attaches to the dryer cabinet. There should be a green screw in the cabinet for attaching the wire. If not, you can always drill a hole for a ground screw.
The loose green wire you see is the reason the code was changed to a 4-wire cord.
Posted on May 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: kenmore 400 electric dryer, installing a 4 wire
Hi
Thanks for using FixYa. Please check this picture which will sort out everything for you:
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
Dryer is not blowing heat
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Aug 17, 2014 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore gas dryer model 110 775 42600 won't heat what is wrong
Jul 04, 2014 | Kenmore 500 6952 Dryer
My gas kenmore 80 series is not heating?
May 20, 2014 | Kenmore 80 Series Heating Element -...
I have a gas powered kenmore dryer but my new home does not have an gas outlet instead the new home has only an electrical power 220 outlet I want to use my new dryer in my new home. How do I convert from...
You cannot convert a gas dryer to electric. Do you a natural gas line for your furnace? A plumber can easily T into the mainline and run a drop for your dryer. This would be cheaper than buying a new dryer. If you do not have natural gas in your house you will need to buy a new dryer.
Jun 30, 2011 | Dryers
I have a lg dryer with a 220 electric hook up plug and in my house there is only a 110 electrical outlet. is there any way I can just change out the cord to a 110 electric cord and use it?
No. the new dryers have to have a 220V power. You first have to replace or add a 220 outlet on the wall that matches the connector on the dryer.
Jun 26, 2011 | LG Dryers
What do you do if your out let for your house is only putting out 110 instead of 220 at the outlet.
Depends ... what is 'normal house voltage' where you live?
If you are installing a new electric dryer in the USA, typically, they operate at 220 Volts. If there is no special outlet at the place where you want to use the dryer, you will have to have an electrician install the proper gage wire and outlet for you. Expect to pay up to $200.00 or more for this installation from the house main panel to the dryer location.
If there is a gas line at the location, you may want to consider exchanging your electric for a gas model.
May 27, 2011 | Kenmore 700 6973 Dryer
Moved to new house and it's not a gas hook up just electric
You will have to replace the dryer with a electric one or have your local gas company install tank and run lines for you unless there's natural gas line where you live which you will need the city come and run a line or a qualified gas technician come do it but this will be costly. I would recommend buying a good quality used one or a new one it would be cheaper. Also since the gas prices have been sky high on propane and NG allot of people have switched to electric over the last two years and most appliance company's even mine wont trade or give anything for it just a fyi but good luck and hope this helps.
Jan 10, 2011 | Hotpoint NVL333GY Gas Dryer
Have a kenmore dryer that wont heat heating element is fine and ive replaced the fuse
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
Feb 19, 2010 | Kenmore 64742 Electric Dryer
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
Kenmore 63942 Dryer Logo
2,695 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
