Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung HLP6163W wont turn on
My dlp made a popping-crack sound and it shut down. I replaced the lamp and now the lights on the front show the lamp trying to turn on for about 6-8 seconds and then all three lights start flashing . There is a sound like the fans are on and a low deep hum while trying to turn on but nothing else. ANY HELP WOULD BE VERY APPRECIATED!!!. THANKS.
  • 4 more comments
  • billandjodi Oct 15, 2008
    We were watching the set when it made a shattering-crack sound and then went off. The lights were flashing for a defective lamp. We replaced the lamp but the TV still will not turn on and the defective lamp lights are still flashing.
  • dtirelady Oct 16, 2008
    tries to turn on then all three lights light up you can hear the fan running but no picture,no sound
  • jboy49 Nov 19, 2008
  • Pennyl3 Dec 16, 2008
    I have a big problem with my Samsung HLN617W 61 in. Rear Projection HDTV Television! It was made in 2004 in Mexico. I cannot turn it on--all the three lights are blinking! I hate to throw it away, so I replaced the lamp. But that makes no difference. I recently ordered a color wheel and decide to try it. I will let you guys know if it works. Anyway, I will never buy anything made by Samsung!
  • Anonymous Feb 20, 2009
    Same exact problem as as VINCEM'S, but I have an HLP5063. As soon as TV is plugged in, it begins the loud humming, and sounds like some clicking. There is no picture. The only way to power off is to unplug it.
    From my research, it seems to be a color wheel problem, but if anyone can give more clarity, I would appreciate it greatly.
  • jkuk1375 Mar 25, 2009
    I have the same problem what should I do?
I went to sleep my tv was play i woke up and don't work so i turn it on popping crack sound and it shut down what do nowno tv
Posted on Sep 27, 2008
My Samsung DLP tv Model HLP6163w/xaa shuts down , the two green and timer red ligts fliker
l need some information here:
Does it work at all or fail upon trying to turn it on?
When was Lamp replaced last and have you inspected the lamp?
Have you or do you hear any high pitched whine or grinding sound or even a loud fan like sound?
Dec 06, 2012 | Samsung Televison & Video
Samsung 50 inch dlp shuts down
have you examined the color wheel which faces the lamp in the set to see if shattered or missing pieces of the wheel?
Jun 16, 2012 | Samsung Televison & Video
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
The screen on my Samsung DLP tv turned off with the volume still playing. The lamp light started flashing. We replaced the lamp and it doesn't seem to have fixed anything. What could be wrong?
Lamp Fan could be defective or the Ballast Board ,it is what powers Lamp.
Encompass Parts Distrubution 1-800-638-3328
Go to this website and type in your Model# for list of Parts /Prices
Oct 07, 2010 | Samsung HLP6163W 61" Rear Projection...
My TV turns off by itself. It is a Samsung HlP6163W. Service Model HLP6163WX/XAA. The two green lights flash at the same time. I think it is overheating the bulb. How do I fix it.
Lamps don't really last very long typically 1 to 3 years depending. You may just need to replace the lamp. A burner gap of a lamp expands as the lamp warms up. If the gap is too large due to age (normal usage) the lamp will fail to light or shut down once the expansion occurs. The solutions to either problem is to replace the lamp.
Mar 15, 2010 | Samsung HLP6163W 61" Rear Projection...
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung projection tv
change lamp change fans
and replace color wheel.
make shure to remove jumper when replacing samsung color weel.
the jumper is black on the back panel of dmv modual.
jumper needs to be removed due to the new air cor motors thay are yousing, i had this same situation at one time.
Dec 16, 2008 | Samsung HLP6163W 61" Rear Projection...
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLN617W 61" Rear Projection HDTV Logo
257 people viewed this question
Henry  Thomas
Henry Thomas
