Question about Lexmark Z600 InkJet Printer
Lexmark z600 there is paper in port. ink levels at 40%. but printer keeps saying out of paper
I lost my cd software and i need to down load it but am having problems
Posted on Oct 20, 2008
  • martin_chibe Oct 20, 2008
    i need drivers for the Z600 printer
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
Installed new printhead,took new ink I had just put in old printhead and put it back in new printhead. Will print nothing.just spits put blank 4x6 photo paper it says to load in to get calibration.Then it...
The document specs of your printer is given below:
Document & Media Handling Max Original Size Legal (8.5 in x 14 in) Original Type Sheets Min Copy Size 3.5 in x 5 in Max Copy Size Legal (8.5 in x 14 in) Standard Media Capacity 100 sheets Output Trays Capacity 50 sheets Document & Media Handling Details Input tray - 100 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ Output tray - 50 sheets size: 3.5 in x 5 in - Legal (8.5 in x 14 in) ¦ ADF - 3.94 in x 5.9 in I would rather suggest to take a print in normal A4 size plain paper and see what you get. Please revert back Suspected 1) paper scanner faulty not able to judge paper.
Sep 10, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
How do i check my ink levels on officejet 6210 it says to go to preferences but when I hit the button there is no tab for services to check the ink level
What OS do you have on your computer?
Do you have the full software installed, if available for your OS? See http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=421991& , select your OS and then click Next. The Ink Level indicator is part of the HP Toolbox or HP Solution Center (depending on the printer). So without the full-software, the service tab (and ink level information) sn't available.
For the OfficeJet 6210, the driver for the all-in-one is part of the Windows OS for Windows 7. So the ink level information isn't available at the computer.
The other way to get the ink level is to have the printer do a print quality self-test. Put plain white letter, A4 or legal sized paper in the paper tray. Then press Setup (on the printer). Press 2 and 5 (selecting Print Report and Self-Test Report). The ink level may not be given exactly. (Use the quality of the ink blocks to determine if the ink needs to be replaced.)
I hope this helps.
Aug 25, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Installed new ink cartridges mx 300, compatible B&W 40, color 41, printer status still says low ink, printing as if it is low ink. properly installed, tape removed, what i miss? can I check something...
Do you know what?. As a matter of fact,it is not compatible cartridges you buy. It is refurbished cartridges that repackaged with other brand as if this is their product. I say it is original cartridges that once empty and repackaged. So that's why when you install the cartridge the ink level stays low. You can make it sure by comparing it with new original cartridge. Find original cartridge,may be you can borrow from someone,which ink level still full and install on your printer. I am a hundred percent sure ink level will show properly :).
Feb 19, 2011 | Canon MX300 Office All-In-One Printer
Ip5000 printer worked perfectly but now comes up with three orange lights stating a paper jam. There is no jam. Shop says it is a timing problem but suggested a new printer. Paper roller keeps rolling...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Hope this will help or else you mother board has errrors.
Sep 28, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
My printer keeps saying there is a paper jam. But
If the printer is sensing a paper jam, then there is either a small piece of paper jammed under a sensor, or the sensor is falsely reporting a jam.
If you cannot find the sliver of paper, I suggest that you contact Canon Technical Support or take the printer to an authorized repair shop.
Don
Oct 17, 2009 | Canon Office Equipment & Supplies
I just put a new cartridge in my dell AIO 946 printer but it still says the ink level is low.
well this always happens with all printers. I have a HP, in the beginning when I first bought the printer, it came with a ink cartridges, it showed the levels. But after the ink was all gone, it showed empty ink levels. The best way to solve this is to ignore this. When you see that your paper is poorly printer, then your ink cartridges need changing.
Aug 28, 2009 | Dell 946 All-In-One InkJet Printer
Both the ink and paper feed button are flashing (Epsom c66 printer)
check for a paper jam or an ink cartridge jam which was not properly aligned. usually thse are reasons. also check your ink levels and never touch the part of the ink cartridge connected to the printer. just keep pressing cancel or X, cancel the documents, then load another paper then press on start copy. this should work.
Jul 08, 2009 | Epson Stylus C66 Inkjet Printer
Error after reloading color ink
Remover Black and color cartridges. Place small paper towel to protect ink outlet on bottom of printer. Use WD-40 spray on copper surfaces,both sides(Blk& Color). Dry surfaces with paper towel. remove small towel placed in bottom . Reinstall both cartridges. This cleared my 1102 error. Die Rote Baron!
Jun 10, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark Z600 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
