I know this sounds stupid but check the ground at the battery, ive had the same problem,everything worked exept the starter and it was from the battery ground being loose
Check coil pack, if more then one is bad, car will not start, or would be running only 3 of four cylinders. Timing may be off a bit do to no fire in a cylinder. This would cause either hesitation, or no start, or hard start.
