Amstrad digibox Box is stuck with power light red. I have been to sky and they have downloaded software still stuck at red. Seems like I need a new box.
    Problem Solver:
  • 4 Answers
If you have had new software downloaded on the box and it still dont work then you will need a new box. have you tried a system download if not then take your viewing card out the sky box then take the power lead out count to ten. then wilst pushing the backup button on the front of the sky box plug the sky box back in keeping the backup button pressed , wait till the on screen message says sytstem download do not disconnect from mains blaa blaa take your finger off the backup button and wait till the tv screen goes blank. give it about 60 seconds then try turning the sky box back on this should work.
Posted on Sep 25, 2008
What type of mini sky receiver box do I need for a 4f3006 Amstrad box 501 201.
You want the version with the Ethernet port and external power supply to go with your
4f3006 Amstrad
Oct 16, 2014 | Televison & Video
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
Sky digibox software download
yes you can download the latest software to your digibox..... you must do the followings to the letter..
1)remove your sky card
2)turn your box onto stand by
3) unlpug from the mains socket
4)when you plug it back in hold the back up button on the box in for 10 seconds and release it
all lights will come on the front of the sky box and dispay downloading software on your tv
5) when it says welcome to sky put you veiwing card back in
job done.............
Jan 24, 2011 | Computers & Internet
Sky + remote rev 8 works tv but will not work
TV
SELECT + i (flashes twice)
0
job done
Cheers
Little Dish Fitter
Aug 29, 2009 | Star Manufacturing International R/C Sky...
Manual. need to know what the connections are for
User guide or Manual for Amstrad Sky+ ...YYY
2 posts - 2 authors - Last post: 27 Jun 2007
I need to add a second sat lead from the LNB to the Box. None the less I need a book of words that tells me about the Amstrad 180 sky+ box. ...
forums.vnunet.com/message.jspa?message... - 29k - Cached - Similar pages -
Sky Digibox remote control codes for your television
This User Manual is the ideal solution if you've bought a Sky Digibox without one. .... it ALSO operated ALL of the functions on my Amstrad Sky+ receiver (not .... in the Digital Installation Manual or via the Sky Customer Service option in ... This actually selects Sky+ mode, but a Sky+ remote works a sky HD box. ...
www.satcure.co.uk/tech/digicode.htm - 49k - Cached - Similar pages -
User manual AMSTRAD SKY PLUS - User guide AMSTRAD SKY PLUS ...
User guide AMSTRAD SKY PLUS. USING YOUR SKY+ WELCOME TO YOUR SKY+ BOX GUIDE .... to repair your Sky+ box. For repairs, please contact Sky Customer Service. ...
safemanuals.com/user-guide-instruction... - 98k - Cached - Similar pages -
For Sale : Amstrad Sky+ Box and QED 1.5m Squart Cable - AVForums.com
Due to an upgrade to Sky HD I have for sale my old Amstrad Sky+ box (model no. DRX180). ... Will try to find the manual for it as well. ...
www.avforums.com/forums/home-cinema-hi... - 102k - Cached - Similar pages -
Amstrad Sky+ Box - HELP PLEASE! - Sky+ - Digital Spy Forums
6 posts - 5 authors
Amstrad Sky+ Box - HELP PLEASE! Sky+. ... The Specifications in the manual state: Hard Drive: 160 Gb (with 80 Gb for personal use); the packaging also has ...
www.digitalspy.co.uk/forums/showthread... - 55k - Cached - Similar pages -
amstrad sky plus on standby
Following the instructions at the top of page 66 in the Manual fixed it. .... Go back and wait by your sky+ box and you should see the red recording light come on, ... Sky & DLM, Sky Broadband Service Status, SkyUser Bandwidth Meter ...
www.skyuser.co.uk/forum/sky/17069-amst... - 117k - Cached - Similar pages -
sky+ box keeps making beeping noise. - Cable Forum
15 posts - 3 authors
can anyone tell me how to stop sky+ box from making a beeping noise, ... thanks paul ill read manual & see if that helps. my sky+ is an amstrad pvr3. ...
www.cableforum.co.uk/board/64/33616556... - 87k - Cached - Similar pages -
Sky+ box amstrad dx280 - FixYa
Technical Support, Instructions & Repair Service. Home | My Expertise | Sign In ... Related Searches: sky remote, sky box, amstrad, skybox, sky manual ...
www.fixya.com/support/t1223689-sky_box... - 49k - Cached - Similar pages -
MobilePhoneMadness.com - GUIDE: Upgrading Your Sky+ Box
Amstrad Sky+: Equal in size as the Pace Sky+ V2 and looks identical, ... We hope Sky will fix the V1 firmware at a later date, as there no manual fix we can ...
www.mobilephonemadness.com/forums/arch... - 13k - Cached - Similar pages -
Amstrad DRX 180 - Review - How did we live without it???
The problem with the cable service, however, is that when you look at the ... No matter which Sky+ box you end up with, the instruction manual is the same ...
www.ciao.co.uk/Amstrad_DRX_180__Review... - 82k
May 19, 2009 | Televison & Video
Can't get sky remote control to work
i have a amstrad sky box the remote has the record button on it.
i did not change the batteries in it now it wont work the sky box at all.
HELP PLEASE....
Oct 08, 2008 | Televison & Video
Sony kdl40v200
I work for sky as an Engineer (not a subby)
HDCP is the encryption sent down when a program is transmitted. Over the years I have had several jobs where this is the case.
What you can do to fix the problem is Download update for your sony bravia telly this will fix the problem. There is another solution, if you get another engineer out ask him to put a different manufacturers box in..... Sky HD is made by Thomson, samsung, pace, Amstrad,
both solutions have worked for me when coming across theses faults whilest installing sky... The first one is going to be your best option... for example at the minute all I am getting when i go to pick my HD stock up is Amstrad. No other manufacturers so you may find it hard for the engineer to source you a different make.
If neither work. Force a download to your HD box (they have been updating the software recently so this may also work for you.)
Take the power out the back of the HD box. hold down the Standby button then reinsert the power. hold Standby button in until all light are lit on the front of the box... Then wait 10 minutes (better off making yourself a cuppa) give that one a try.
Hope ive been of some help to you
Little Dish Fitter
Sep 17, 2008 | Sony BRAVIA KDL-40V2000 40 in. LCD...
Pace Sky plus box
You have 2 choices, software reset or hardware reset. It's up to you what you try, but please read the advice in full before starting - if you break your box, please don't blame me!
SOFTWARE RESET
The following is copied from http://www.ecademy.com/node.php?id=73309
This is useful if your disk usage percentage doesn't go down even after clearing programmesfilms off.
The following is offered on an ADVICE only basis, take care when making changes:
WARNING following this advice is totally at your discretion and anything which happens to your digibox as a result is your responsibility, not mine. You will lose all recorded programmes from your Sky+ Planner.
Sky tech support can talk you through performing a system restore over the phone. To do this yourself, press 'services' on your Sky plus remote, then select option 4. Next press 0, 1, select - you should now see the engineer's menu. Choose option 8, 'Full System Reset'. The box will now take a few minutes to reset itself
Try pausing or recording again, and if the problem persists disconnect the digibox from the mains power. Press and hold the 'left' and 'right' navigation buttons on the front of the digibox whilst you reconnect the mains power. Continue holding the buttons in for about 20 seconds, and when the ring of light on the front comes on, press the 'select' button on the front of the digibox (between the left and right buttons you were holding). The Sky+ recording logo lights will spin backwards and, according to the Sky engineer, this will "clear the hard drive".
Once this is done, disconnect the digibox from the mains power again and this time press and hold the 'back up' button whilst you reconnect the mains power. Continue holding it for about 15 seconds until 3 lights on the front of the box come on and you get a full-screen message saying "Updating system software. Do not disconnect mains supply or satellite dish."
Leave the digibox doing its thing for about 10 minutes and it should be fixed! Try pausing and recording things again... hopefully you've just saved yourself £65
If you've not been so lucky, you'll have to get Sky to fix it for you. Some people report that if you ask to cancel your subscription Sky sometimes offer a free callout to fix the problem - you're more valuable to them as a paying customer than the cost of an engineer callout
Sky customer service's (seemingly unpublished) freephone number. You need to dial 0800 731 6965, then option 2, option 4 March 9, Sky have closed this Freephone number
HARDWARE RESET
Copied from http://www.digitalspy.co.uk/forums/showthread.php?t=484098
Full System Reset via front panel:
  1. Remove power at mains.
  2. Hold LEFT+RIGHT.
  3. Apply power, wait for ring to light.
  4. Release LEFT+RIGHT, press SELECT.
  5. Ring cycles backwards while disk is quick formatted.
  6. If format sucessful PLAY lights up, if not RECORD lights up.
  7. Box goes into standby - wait 30 seconds are wake it up.
Warning: Full System Reset deletes all your recordings and planner entries.
Aug 07, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Samsung LE32R7 Picture Flashing
You need to get your sky box changed! just ring them up and tell them your problem. the TV is a known issue with certain boxes.
Feb 14, 2008 | Televison & Video
Samsung LE R88 BD LCD TV / digibox problem
Hi.
Its a long shot but try this,
It can cause problems when you switch set to & from stand bye.
Check that you are viewing a digital TV channel
Enter the menu and navigate to:
Setup > System > Software Upgrade > Standby Mode upgrade
Change the setting to Off.
I cant gteee that this will sort your problem out so post here if it doesnt & I will check samsung data base.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
312 people viewed this question
 Grubhead
Grubhead
