Question about HP Officejet 6310 All-In-One InkJet Printer
Black Ink cartaraige leaked
Black ink leaked out and dripped onto the bottom pad.  Dried ink is almost a half inch high ! How do I clean the mess? Can I take the top of the printer off ? Thank you... Mike
  • 1 more comment
  • nanicc87 Sep 23, 2008
    Same thing happened to me! And now my printer has gone nuts and keeps flashing lights and displaying a RESET POWER sign! How do i clean it? Do i service it?
  • kcwallace01 Feb 18, 2009
    Black in always runs out quickly..checked and have the same ink blob under the cartridge. I just keep replacing the cartridge but at $30+ per cartrisge, that stinks. Any help on how to diagnose would be wonderful.
    Karen
    kcwallace01@gmail.com
  • Anonymous May 05, 2009
    I thought I figured out the problem when I took the door off to disconnect the ribbon wires (a recommended fix). There was black in ribbon wire slot. I cleaned this out but it still does not work. I did figure out that the printer cartridge does not get back to the return position and error each time when the carriage is at the same location. (Just outside the cartridge replacement side).
    I tried cleaning the ‘stepping’ sensor and plastic that has tic marks, but still no progress. Let me know if you come up with anything. Thanks.
computafixa
  • 317 Answers
SOURCE: Black ink leaking from bottom of printer!
There is a small hopper inside of the printer, called the cartridge holder, this is where the excess ink is wiped off of the cartridges, and is just left there. it is usually on the side where the cartridges stay when they are idle. The easiest thing to do, is take the cover of the printer off, and blot the ink out of the hopper, do not use any detergents, or liquid cleaners, as this will ruin the cleaner head for the cartridges.
Posted on Jan 18, 2008
Drummernick
  • 440 Answers
SOURCE: Printer seems to be leaking ink?
take those out are uusing off brand ink
Posted on Feb 03, 2008
Khalsa007
  • 79 Answers
SOURCE: ink build up under cartridge
if u look at the back of the unit there is a back door which u can take out .
or u can open the front access door [ from where u insert the cartridge ] , in case u r not able to clean it from there .
u might need to get the unit serviced ,for that either contact HP customer care at 1800 474 6836 or on-site Repair Center at 800-633-3600.
Thanks
Posted on May 29, 2008
SOURCE: cleaning up the mess of black ink leaking
Wasn't sure whether to mark this a solution or sympathy because I have the exact same issue. The sponge is stuck on two plastic tabs that jut out, one in front of the cartridge stopper—a platform that is normally retracted but which extends if you shut the power off—and the other in the back of it. You can see them if you look carefully.
Once you get the sponge out, you can wash it in 97% alcohol or distilled water. Unfortunately, since half of the sponge is under the cartridge stopper platform, you may not be able to get it entirely out of the printer (at least I wasn't able to). Instead, I just soaked up as much ink from the well as I could with alcohol soaked paper towels—a lot of paper towels.
Posted on Jan 01, 2009
pacificink
  • 13 Answers
SOURCE: ink cartridges will not slide due to leaking ink underthe printer
Sorry to hear about the mess. Let's start with the clean up of the ink. Use a dry cloth or paper towel to wipe up the ink that has spilled out of the cartridge. Wipe gently so you don't do any damage to the internal components of your printer. The ink will likely color the inside of your printer - That's okay. Just make sure you get anything that puddles. It should not look wet.
On to the non-moving cartridge carrier. The standard fix for this is to do a hard reset on the printer. Follow these steps.
1. Unplug the power cord and remove the paper from the paper tray.
2. Move the carriage all the way to the right, close the lid and reconnect the power cord.
3. The printer will make some noise as it starts back up. Wait until it stops making noise.
4. Open the printer lid. The carriage should return to its normal position.
5. Try printing again.
If this does not work, then damage has been done to the internal components. You will need to get the printer serviced by a repair person.
Posted on Jul 24, 2009
How to replace ink absorber canon mx310
Unfortunately this is not an end user item. The ink absorber is basically a big felt pad. When the printer cleans the print heads at the beginning of the print cycle it spray ink on the pad o clean the printhead nozzles. The printer is programmed to count these cleaning cycles and when the number is up it gives the ink absorber error on the display. The printers use the ink absorber to prevent the used ink from dripping out of the printer onto you table or desk. By the time the absorber registers that it is full it really is soaking wet with ink, you don't want to deal with that mess. It really is like an end of life for the printer notification. You would have to open the printer, remove and wash the absorber and clean the holder then reset the counter in the printer just to get t going again. The manufacturers don't even sell the absorbers because they treat this as a non-repairable printer. Sorry for the news but I have been a printer tech for 15 years and that's really the best thing to do, get a replacement printer.
Jul 19, 2012 | Canon PIXMA MX310 All-In-One Printer
Ink drips out from bottom right hand corner
most probably your printer waste ink have overflow... please replace the waste ink pad to avoid further damage...and mess...
May 28, 2010 | HP Office Equipment & Supplies
Photosmart D7360 leaks black ink out the bottom of the case, below where printer head parks. Otherwise works fine.
Its a sponge in the drip tray underneath the print head. It tends to fill up, especially if you're cleaning your print head quite often.
Its full of ink, and so needs to be dried out. The easiest way would be take it out, rinse it under the tap and leave it somewhere warm to dry out.
If you can't take it out, try and decant the ink, blotting paper, sponge as best you can and give it a while to dry.
May 08, 2010 | HP Photosmart D7160 InkJet Printer
My black ink printed very faint lines, changed the cartridge and did a print head cleaning, and now it doesn't print black at all.
Make sure you didn't get an old cartridge where the ink is dried up. Check the bottom of the cartridge where the ink comes out. Does the ink seem fresh and liquid or old and sticky or dried out? This happens. If its not that then you might have clogged jets on your printer head. To clean these you have to drop a few drops of isopropyl alcohol down into the inkjet heads (the little holes that the ink from the cartridge goes into) and allow it to soak overnight. The next day wipe with a q-tip. Place a cloth beneath the inkjet heads to catch any drippings overnight.
Mar 27, 2010 | Canon MX700 Office All-In-One InkJet...
Lexmark 1240 black ink prints in streaks.
Take the cartridges out, then unplug the machine so the cartridge holder stays in the middle. Take a bunch of wet q-tips and clean all around where the ink would come out. Check rollers and anywhere the ink could have dripped. Double check the maint. station, sometimes there is a wiper thingy that jumps up to wipe the inks.
Apr 29, 2009 | Lexmark X1240 All-In-One InkJet Printer
There is a ink resovier where the cartridges are cleaned of excess ink after a job. That gets filled over time and gives you the leakage described. Very messes job to clean it.
Sep 10, 2017 | HP Photosmart 3310 Printer
Cleaning up the mess of black ink leaking
You shouldn't need to clean it. Just squeeze it like you would a sponge using something like a paper towel. This is a messy endeavor, be careful.
May 22, 2008 | HP Officejet 7210 All-In-One InkJet...
Carrage jam - error message
if you have had this for some time, the ink pads and their well may be clogged with dried ink. look at those. If so, you will have to take them out and clean out the well, then the ink heads should move freely.
Jan 28, 2008 | HP Photosmart 2610 All-In-One InkJet...
Epson Stylus Printer CX4600
I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
Hope this helps
Dec 03, 2007 | Epson Stylus CX4600 All-In-One InkJet...
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
HP Officejet 6310 All-In-One InkJet Printer Logo
64 people viewed this question
Seeker5211
Seeker5211
