Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Freezer is not freezing and refridgerator is not cold enough
Everything in the freezer is thawing out and the refridgerator is not cold enough WE HAVE A KENMORE SIDE BY SIDE FRIDGE AND THE LIGHT IS ON AND THE FAN IS RUNNING. THE FREEZER IS DEFORSTING AND THE FRIDGE WON'T STAY COOL. THERE IS NO WATER LEAKING OUT.
    New Friend:
  • 68 Answers
Thanks for posting your problem to this forum.
Please check inside the wall of the freezer on it s back for frost buildup. If there is any frost, the defrost system is not working and the coil inside the back wall is frozen over stopping air circulation to the refrigerator. Defrost system has a electronic or thermostatic timer that switches a heating element on to melt down the frost and also got a switch that shuts off the heaters when the coil is warm enough for all ice to be melted.
If you have the frost, locate the defrost timer and turn the clutch head screw clockwise SLOWLY until you hear one audible click, the compressor will shut off and the system will be in defrost.
After about 20 minutes the refrigerator should start automatically. If it does not start after 25 Minutes turn the timer screw again to get the second click. Refrigerator will then start. Replace the timer. If it restarts after around 20 minute but does not defrost either the heater or the thermostat in the defrost system is out of order. Check to make sure freezer fan blowing & fan by compressor, No blockage in supply or return vents, Look inside freezer to make sure NO frost is coming, if it does, it indicates problem with the defrost mechanism
Please try & Reply.
Posted on Sep 13, 2008
  • Utsav Bhattacharya
    Utsav Bhattacharya Sep 13, 2008
    Please be remided that Do NOT ever try to BREAK OPEN anything of the sealed system. If you are unsure, please refere to our experts available with the Repair Directory or refer to an authorised service personnel.
    Best of Luck.
    President:
  • 1,952 Answers
Door problem side by side refrigerator and having a problem with the freezer door. One has to make a big effort to close the door as It does not shut as freely as the refrigerator side does. What is the problem with the freezer door and how may I correct It? The gaskets are all in great condition and there Is not any food packages blocking the closing of the door.. Thanks a lot! ur comprasor is check
It sounds like the sealed system has developed a leak. IT IS NOT REPAIRABLE!!! Whatever you
  • mohammed marika thambi
    mohammed marika thambi Sep 13, 2008
    One copper tube coming from the compressor feels cool (not cold) and
    the compressor itself feels warm but not hot (after running for a
    couple of days)I checked the air ways and they are clear. I took the
    back off of the freezer again and this time there was some frost on the
    coils in the freezer compartment. (top coil only) The only thing I
    don't know about is the relay but I would think if that was bad the
    compressor would not warm and the copper tube would not cool. Is the
    copper tubes coming from the compressor suppose to be cold instead of
    cool
    when buy a refrigerator?
    Genius:
  • 3,422 Answers
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
  • Priya darshan Sep 13, 2008
    If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
    First, answer these questions:
    • Is the refrigerator completely dead? If so, see “It's stopped completely.”
    • Is the thermostat knob turned to the proper setting? If not, reset it.
    Next, see if the compressor motor is running
    The
    compressor is a football-sized case with no apparent moving parts. It's
    on the outside of the refrigerator at the back near the bottom. If it
    is humming or making a continuous noise and your refrigerator is still
    not cooling, there may be a more serious problem with one or more of
    several different components, we recommend contacting a qualified
    appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Freezer is to cold and refrigerator not cold enough. When you open freeze it is always running
Sounds like the fan that cools the lower refrigerator is inoperative or it's fan blades frozen up.
Try defrosting. You will have to remove everything and remove the access panel to the fan to ensure it's fan blades are free and not frozen up. They have a built in inherent safety feature and sometimes they will work properly again when thawed out. More than likely the small fan motor burned out and will need to be replaced. There are appliance parts stores every were or call the mfgr parts department.
Once replaced your can restore your freezer setting to where it belongs. There is a dial that raises and lowers this setting.
The small fan draws air from the freezer and cools the refridgerator. It is also on a thermostat and usually has a dial to set the way it cycles and determines the temperature.
Cheers,
TF
Jun 02, 2011 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Temperatures not staying cold, then getting too cold. First everything in freezer thawed out. Then, fridge wasn't cold enough. We moved everything to freezer just to keep colder (not to freeze). Then, days...
assuming fan now working. clean out vents/ drain holes (make sure no ice in bottom of freezer or in fridge unit)i.e. a total defrost.then check door seals all okay(no air leaks) if unit was trying to defrost itself and you reset to colder it will need to reset itself.....
Feb 11, 2010 | Hotpoint HSS25GFP Side by Side...
The refridgerator is cool, but not cold.....of course the same for the freezer. the freezer is running, just nor getting cold enough. food is thawing and thermostat is reading almost 40 degress in both...
Je your defrost thermostat, heaters or timer is not working correctly or at all. The freezer has the coils that freeze the freezer and cools your fresh food area. When your defrost does not work these coils become blocked with ice and will not let air from fans pass through!!! Leaving a moderate temp in fresh food area.
Aug 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer coils completely frost (freeze) up--refridgerator warms
Sounds like the defrost timer or something in the defrost circuit. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 11, 2009 | Kenmore Refrigerators
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
GE side by side refridgerator
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Sep 17, 2008 | Refrigerators
have the freon checked for leaks, also check to make sure the compressor is coming on. If it comes on and is warm, boost freon. If the unit is not coming on properly, check the capasitors and compressor
Jul 24, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
137 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
