Question about Vacuums
Hi, we have a Kenwood VC620 Vaccum Cleaner. Can you plz let us know how we can remove the cylinder to clean it up. Thanks.
  • 1,239 Answers
  • hi i think
  • If the spot remover you use alters the color of your carpet, try touching up small places with artists' acrylic paint. If acrylic paint doesn't work, try using a felt-tip marker or a permanent-ink marker of the appropriate color. Go slowly, and blend the color into the fibers.
  • To raise depressions left in a carpet by heavy furniture, try steaming. Hold a steam iron close enough for steam to reach the carpet, but don't let the iron touch the fibers, especially if they are synthetic, because they could melt. Lift the fibers by scraping them with the edge of a coin or spoon.
    ©2006 Publications International, Ltd.
    Depressions in carpets can be raised by steaming (center), then by
    scraping the fibers with the edge of a spoon (right).
Posted on Sep 13, 2008
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
When the switch is turned on the vaccum cleaner starts running instead of,when the hose is connected. removed the earth lines from the unit and truned on the vaccum cleaner. It did the same. What might...
Dirty switch at vac where hose connects go to radio shack get some tuner cleaner spray. spray this switch and plug hose in and out a few times spray again see if this works
Feb 26, 2011 | Broan-NuTone CV554 Cyclonic Bagless...
Just receved this steam vac and noticed the floor was still very wet after using on a small area. looked at bottom and it has the one long stright row of brush and nothing behind(large gap, with some...
If their is problem with the sucction,you should clean or replace the bag seen inside your vaccum cleaner
If any basic part of your vaccum cleaner lost excludes brushes and cleaners you can't use it.
Feb 15, 2011 | Vacuums
I want to open the motor of vassum cleaner
let me know what kind of vacuum it is and the model # and ill walk you through it
Jan 02, 2010 | Vacuums
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
A noise coming from the motor when I`m ready to vaccum
if it were m i would take it back and insit on a new one.something new shouldn't have to be fixed thatd why we buy it new
Dec 31, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Vaccum Cleaner
You can download the manual here and it will tell you how to replace your belt. I could tell you, but I won't have diagrams which the manual does. Let me know if you require more assistance.
Dec 10, 2008 | Hoover U5172900 Fold Away Widepath Bagless...
Vaccum Cleaner
you probably broke the belt so check that. if the mains cord is damaged, you should replace it
Sep 18, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Dyson DC05
try this site
It has service manuals for the DC05.
Jul 28, 2008 | Dyson DC05 Cylinder Bagless Canister...
Vacuums Logo
136 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
