Question about Bosch Nexxt WTMC 3300 Electric Dryer
Electrical requirements for a Nexxt MO# WTMC 5321US
I would like to move my dryer to Belgium and I would like to know if I will need a 240/120 volt transformer to power the electronics inside the dryer? I know the motor will run 20% slower due to the 50/60 Hz. difference.
  • 550 Answers
It would be simpler and cheaper to get a new dryer
most of the world uses a single phase 240v 50hz system, your dryer is designed to run on a 2phase 120v 90degree system.
the common statement that high voltage items like dryers use 220-240v is not strictly true, instead they run off both 120v phases of the 2phase system.
A transformer to produce a 2phase 90degree 120v 20A secondary from a 240v single phase source is expensive and very large.
It would be cheaper by far, to sell the dryer, and replace it with the equivalent model built for 240v single phase, than to buy the transformer and ship the dryer.
Posted on Oct 18, 2008
Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
Jun 05, 2012 | Bosch Nexxt WTMC 6300 Electric Dryer
What could be a cause of water leaks from Bosch Nexxt 500 gas dryer?
Since there is no water lines connected to a Bosch Nexxt WTMC 6500 gas dryer, the water leak has to be from excess water from the clothes you are trying to dry. Which is probably more the problem.
Does your washer leave an excessive amount of water in the clothes after the spin cycle?
Jun 04, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
When the dryer is running it sometimes makes a screeching sound momentarily on and off during the dryer cycle. Some cycles it does not make the sound at all. Is something going bad? It doesn't seem to...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
May 02, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
How do you remove the front panel where door is located
Welcome to FixYa.
I wouldn't do that...there is nothing or very little which can be serviced from the front. ( aside from the door itself and control panel of course ) all service on the WTMC Bosch is done from the back.
**Unplug the unit from the wall before attempting ANY service...safety first**
i.e.
Remove the top...
Then with the top off, remove the back panel...
Once that has been removed, you'll need to remove the rear drum support & drum.
i.e.
Then you can pull the drum assembly out...Now you should see the front of the unit and components, drum rollers, motor, etc.
i.e.
Hope that helps you identify and access what it is you're after for your Bosch WTMC dryer, good luck.
Let me know how you make out or if you have further questions of course, I will help you move further in whatever manner I can.
Good luck.
Regards,
Macmarkus :)
Feb 23, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer is not heating to dry clothes
if its not heating at all, first check electrical and make sure your getting 220 to the dryer if you are more than likely its the heating elements, check them and replace if bad
Apr 26, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer will heat for awhile and then shut off, requiring resetting the reset button.
Must be a restriction of air flow due to having too many clothes in the machine,blocked vent, or lint buildup in the machine.
Oct 21, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Heats and turns but shuts off after about 15 min
This may be an indication of an internal duct restriction due to lint. If it is clean inside there may be a problem with the main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for LG Dryer Parts: http://www.repairclinic.com/LG-Dryer-Parts
www.RepairClinic.com
Feb 03, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer
I have a Bosch Nexxt WTMC 3300 electric dryer. The dryer doesn't heat up. This is the second time this has happened over a one year period. The first time it happened, the technician reset the thermal cutoff, but said he saw no reason why it should have tripped. Can you tell me how to reset the thermal cutoff or offer another solution?
Apr 25, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
122 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
