JVC AV-56WP30 56 in. Rear Projection Television
Problem for JVC AV-56WP30 56 in. Rear Projection Television
Lamp issues
By Wags on May 21, 2006
there is green horizontal lines that appear to be convergance issues. When I cover the Green lamp lense cover, the lines disappear but of coarse the picture is more red. Could this be a bulb or maybe a board issue. Is the G, out of the RGB have any special relevance? I appreciate any advice.
Same Problem
Aug 14, 2008
-   I need the way desrvicio to fit Convergence, after changing the CI deConvergencia for the TV Toshiba TP61G60. Thank you.
priqal@hotmail.com.-   priqal
Jan 31, 2008
-   There are several green lines that begin in left hand top corner of screen and drop down in a semi-circle and finish in the top right hand corner. Is this a bulb problem?-   jasbo
Nov 24, 2007
-   colors do not line up
-   LisaE
Best Solution
posted on May 21, 2006
Helpful)
techman
Rank: Guru  JVC Expert
Rating: 86%, 7632 votes
No its a tube and not a bulb. If thew line is green then theres an issue with the red and blue as the green is stationary on most sets unless thers a green centering ? Its a componet on the convergence board thats bad or going bad but if you replace any components on the board most likly your gonna need to do a convergence alighnment I would let a pro handle this repair unless your an experineced repair tech Good Luck
Was this helpful?
Yes
No
Solution #2
posted on May 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
When I turn my tv on the power button flashes green and then the tv turns itself off and the lamp lcd light starts flashing...whats this mean??
Solution #3
posted on Apr 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
MY SREEN IS DOUBLE THE VISION AND SHOWING GREEN?
HOW DO I GET MY REGULAR SCREEN BACK?
Solution #4
posted on Aug 28, 2007
Not Rated)
TVtimmy
Rank: Apprentice
Rating: 82%, 7 votes
Actually man... you need to find the flyback transformer for the green tube, and adjust the raster on the green screen down a notch. most likely you are dealing with an issue where the coil inside the flyback transformer to your green CRT has a bad spot on it and the coil wiper is setting on top of it causing the resistance value to drop on the overall coil. Find the flyback transformer for the green CRT, adjust the screen coil slowly until the lines fade away. Do not adjust the focus coil. Screen coil is usaully above the focus coil.
Was this helpful?
Yes
No
Popular Solutions for JVC AV-56WP30 56 in. Rear
Questions and Unsolved Problems for JVC AV-56WP30 56 in. Rear
Do you recommend JVC AV-56WP30 56 in. Rear Projection Television?
Answer
Answer
My TV turns on and off randomly. It sometimes turns on in the middle of thw night. Other times we... (More)
Answer
I have a 54' Tantus HDTV 1080i monitor that shows that power is going to the sytem via the red power... (More)
Answer
top left corner has a blueness to it and peoples heads in that spot have a double image
Answer
the power light is coming on but it is making a cracking noise and i dont see any picture
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For JVC AV-56WP30 56 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
