Question about Samsung YP-K3 MP3 Player
My mp4 player can't start
My player can't start. It shows nothing when press power button. ON/OFF switch is good. I've checked the switch. The battery is also OK. But when I connected PC, it flickers to a sandglass. but cant' start. Before this I formatted. But now, The computer did not know it's presence.
  • 1 more comment
  • DIVALICOUS30 Oct 04, 2008
    my player can't start. It shows nothing when press power button. ON/OFF switch is good. I've checked the switch. The battery is also OK. But when I connected PC, it flickers to a sandglass. but cant' start. Before this I formatted. But now, The computer did not know it's presence.
  • Anonymous Oct 08, 2008
    MY PLAYER WONT START OUT
  • Anonymous Nov 22, 2008
    when I connected PC, it flickers to a sandglass. but cant' start. The computer did not know it's
    presence.
It is a chinese mp4 player. A fake Sony. I replaced the voltage regulator IC, small 3 pin smd salvaged from a bad mp3 player. It is a 3 volt regulator. After this it is good again.
Posted on Oct 05, 2008
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
My laptop Toshiba Satellite A660 series With Windows 7 - "W" Key Button not functioning. When started the computer -In start menu search "W" repeats like somebody pressing the key. I...
By 'W', i guess you mean wireless, first remove your power adapter, then next your battery from your laptop. press the power button for 40 seconds(note that nothing will com on since the laptop is not powererd), Next put back your battery(preferably fully charged), then switch on your laptop. Wireless is now enabled but may stil ve switched off, switch it on using FN+F8 keys. Good Luck
Sep 07, 2011 | Toshiba Satellite A660 Series Notebook
1982 Suzuki GS 650GL won't start. I've purchased a
Well the good news is the click indicates the switch is working, when you press the switch the 2poles on the solenoide are joined together alowing the current to the starter,bridge the wires at the solenoide this should put power directly to the starter you wont need to press the start switch, if the engine does not turn over check the connections to both the battery and starter motor,
Jul 25, 2011 | 1982 Suzuki Gs 550 L
My MP4 player won't Start up
Hi, try formatting the player and switch on without music and see what happens the if ok re add 2 mp3's to check if it works fine then re add music
Jan 17, 2010 | Audio Players & Recorders
My mp4 device if i power on it it will start then
for some time now i have beaning using my mp4 player and is good but recently the thing just went off when i put it on again it stated to show load and that is that without going to the main page what do i do,and is a sony mp4
Sep 24, 2009 | Sony NW-E003F MP3 Player
I DON'T KNOW TO START THE MP3 MP4 T.sonic 840 PLAYER
I'm using T sonic 840. For the first time even I don't know how to operate.
Now I know every nook and corner about T sonic 840
When you start charging The animation appears,
When you switch off the charging, you can see goodbye animation.
Now you press the play button for four to five seconds, and the T sonic will be switched on.
I just want to let you know the functionality of the scroll button.
You can scroll down, scroll up and even you can press the button like play button and record button.
When switched on the page will be at Music.
Now just press the scroll button, now the mp3 player will be started.
Cheers...!!!
Jan 06, 2009 | Transcend T-Sonic 840 MP3 Player
The mp4 won't turn off
Make sure the hold switch is not turned on. If not, then hold the power button until the player turns off.
Dec 09, 2008 | Coby MP-C7097 MP3 Player
MY GENERIC MP4 ONLY SHOWS SAND CLOCK
take a paperclip and shove it in the reset hole on the back.
Aug 04, 2008 | Konaki MP4-NS MP3 Player
Delstar MP4...
battery low??
else any breakage of internal circuit.
else battery position is not correct
else remove batteries and now press ON button for two seconds ( do as if your are turning it ON normally.)
this s done to drain the excess power.
now put the battery and then switch ON
Dec 28, 2007 | Audio Players & Recorders
Samsung YP-K3 MP3 Player Logo
77 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
