Gateway 500LS, press power button, begins to to start up, but after a few seconds switches off. If you persevere with a few tries of powr button it may evetually power up.
  • 4 Answers
Let it charge for 1days then try
Posted on Sep 13, 2008
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
Gateway DX-4380 won't start up but the fans begin for 1-2 seconds than stop.
unplug pc, hold power button in for a few seconds, open case, remove cmos battery ( looks like a watch battery) put battery back, start pc. If that does not work then unplug all hardware (cd drives) and try again to see if maybe it is a drive. If nothing works then its a good chance that your motherboard is bad.
Aug 20, 2014 | Computers & Internet
My Gateway M-6750 laptop was working last night but today when I tried to turn it on the power button light flashes on and off and nothing else. I have unplugged it and removed the battery and held down...
Remove the main battery and the power supply charger, allow a few minutes to get rid of any residual charge. Replace the battery, press power, if there is no change, remove the battery. Now plug the power supply back into the laptop, press the power, if it starts up the battery is bad and needs to be replaced.
Jan 13, 2011 | Gateway M-6750 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Screen locks on start and computer does not
ur OS may be corrupted...
u need to reload OS or
try to do this...
power off the machine
switch off power supply/remove power cable from wall outlet.....remove the power cables...from PC power slot.......keep pressing the power on button in the PC for 3-4 mins....WITHOUT POWER....and/or
press the PC switch on button and release it after few seconds many times.....
Power in RAM is locked...and it's locked ur Windows DLL files....
Dec 14, 2009 | ASUS Motherboard P5GC-VM Intel 945GC...
How to turn off TomTom gps one 130
Gps 130 is supposed to hybernate only. It is almost impossible to turn it completely off.
Nov 12, 2009 | Tomtom ONE 130 GPS Receiver
Gateway 3200S. will not begin to power up. a green led is on at the top of the mainboard. that is the only indicator of power.
Dear Rythmickarma,
As you said the main power LED seems to be glowing but the system is not powering on... so there are few things to check here:
  1. Remove all other connections apart from Power supply, keyboard, mouse and monitor and see if that makes any difference.
  2. When the computer normally boots up there is a POST check Beep sound from CPU .. do you here any beep?
  3. When you tap on numlock key on your keyboard, do you see numlock LED toggle between ON and OFF state?
  4. Is there any signal on monitor .. When disconnected from the CPU, the monitor should show Self test signal .. does it happen?
  5. Open the chassis and check if you can feel the spinning of Hard drive...
  6. Remove the power supply cord from the back of the computer and press and hold the power button for few seconds .. this would drain the accumulated power from the CPU components .. now reconnect the power supply and see if that makes any difference..
Please try the above steps and let me know. Hope that helps.
Regards,
Srinivas
Jun 21, 2009 | Computers & Internet
Laptop will not switch on
Shut down the system, disconnect every thing you can possibly disconnect and remove the battery.
Press and hold the power button for 15 seconds. Reconnect A/C power and try to boot up.
If no change, remove the CD/DVD drive and if you feel comfortable, the hard drive. Reconnect power and try to turn on again.
If you still get nothing, check for any loose screws on the bottom of the case and snug them (DO NOT OVER TIGHTEN). Just finger tight so the screw is not turning loosely. Remove and reseat the RAM. If you get no power, remove the RAM and reconnect power to see if you get beeps from the system.
Let me know if you need to go further than this.
Honest1abe
Jan 17, 2009 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
