Question about Refrigerators
I have a Hygena Built in fridge freezer and the freezer is defrosting and the fridge is not coming
    Genius:
  • 1,239 Answers
Hi try this On the refrigerator door jamb, locate a small push-button switch. This component operates the light inside the refrigerator. If the switch is malfunctioning, the light in the unit may stay on, and the heat from the lightbulb can cause cooling trouble in the box.
Step 1: Check the bulb to see if it is burned out. If not, depress the push button on the door switch.
Step 2: If the light stays on, clean the switch with a cloth. Then remove the switch from the jamb. Remove retaining screws hidden by a plastic trim piece, pry the switch out of the jamb with a screwdriver, or pry off the jamb trim to expose the switch. Then test the switch with a VOM set to the RX1 scale
Step 3: Clip one probe of the VOM to each terminal of the switch and press the push button. The meter should read zero. If the needle on the scale moves above zero, replace the switch with a new one of the same type.
Step 4: Connect the new switch the same way the old one was connected.
Posted on Sep 13, 2008
Fridge not working but freezer is. Why?
I presume it is a combined fridge/freezer. the reason for this is probably because it uses 2 compressors one for the fridge and one for the freezer. sounds like the fridge has lost its gas or the thermostat has packed in. turn the thermostat up and see if you can hear the compressor start up. if not then you will have to either replace the fridge freezer or get a repair person out to look at it.
Mar 02, 2016 | Refrigerators
Defrosting freezer
Not normally, just set the thermostat to Defrost or Zero depending on the make. Most fridges have a built-in heating coil to aid in deprosting.
Bruno
Sep 06, 2014 | Neff K9524X4GB
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
Hygena fridge freezer APM6855. In holiday mode. Freezer ok. Ice in bottom of freezer .fridge not working
Try defrosting freezer. If still not working, you may need to have unit recharged.
Jul 17, 2013 | Freezers
Got an APM6855 with LCD display. The defrost heater element is open circuit. Does not seem you can buy/fit a replacement. Anybody got any ideas please ? Wondered if anyone has ever tried to fit ano...
This is what i found but im not sure what the age of your unit is. Hope this helps.
http://www.espares.co.uk/part/fridges-and-freezers/hygena/apm6855-0/p/1084/1037/0/1332606/1110133/refrigerator-no-frost-pro.html
Apr 24, 2011 | Hotpoint Refrigerators
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to defrost.have not plugged it back in yet.but in the freezer behind the panel there was ice build up to the right of the evaporator fan on the plastic scroll.i cleaned that upturned it on and noticed that there was very little air coming through the top air scoop vent in the fridge side.when I open the freezer door it allows more air though(probably to compensate).anyway I read alot on this issue and some say it's the defrost timer boardsome thermostat.the compressor stays pretty hotbut the freezer works fine.please help.
Jul 07, 2010 | Refrigerators
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Fridge not cold
ice build-up on the back wall indicates a defrost issue, check the defrost items. check the defrost timer, the defrost heater and the defrost thermostat, if you need more details let me know.
Apr 02, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
