Question about Kenmore Brew 'n Wave 63992/63999 Microwave Oven
CHANGING LIGHTBULB ON MICROWAVE
I HAVE A KENMORE ULTRAWAVE MICROWAVE. hOW DO i CHANGE THE LIGHTBULB? THE SCREWS HOLDING THE SHELL ON ARE SPECIAL ONES.
    President:
  • 3,130 Answers
They should be torx # 15 0r # 20 this is not aifficult tool set to get unless the manufacturer put high security type torx and those have a small nipple in the middle of the screw so the tool has a small hole in the middle of the end. Good Luck
Posted on May 21, 2006
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 10, 2014 | Kenmore Microwave Ovens
How to replace light bulb in combination oven model acm1580ab
Cannot find your model number, please provide make and model.
Jul 23, 2008 | Amana Microwave Ovens
Cuisinart microwave CMW-100. How do I change the lightbulb?
You need to remove the cover from the oven. Pull the plug first! Remove the Philips Screws. There are two special screws that are meant to prevent your proceeding further. No standard driver will fit these screws. You can remove them with small pliers gripping the outer edge of the screw and turning counter clockwise. If you are not familiar with capacitors, get somebody who is familiar. The light socket snaps in. Unsnap it. The lamp is taped to the socket with cellophane tape. I have never removed the lamp nor do I know the number. Do not plug in the oven with out the cover!!!!!
Jun 30, 2012 | Cuisinart CMW-100 Microwave Oven
Change lightbulb
You must remove the cabinet shell, it is held on by sheet metal screws, remove them all the bulb is inside.
Jun 29, 2012 | Sharp Microwave Ovens
Oven light jvm1540dn1ww
# 1 Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.# 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.# 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.# 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.# 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.# 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
Regards.
Jan 28, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Changing the light bulb
Regards.
Jan 05, 2012 | Panasonic NN-H264 Microwave Oven
How to replace lightbulb inside microwave
  • 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.
  • 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.
  • 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.
  • 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.
  • 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
  • Oct 27, 2011 | GE JVM1860 Microwave Oven
    Jvm2070sk02 interior light does not come on can the bulb be changed?
    HELLO.
    When you open the door on your microwave, it sends an electrical current to the halogen lightbulb mounted inside the microwave. The signal turns on the light and illuminates the inside of the microwave.
    In addition, while cooking your food, the light illuminates so you can monitor the condition of your food while cooking. While the bulb generally lasts a long time, when it burns out, you must service your microwave.
    THANKS.
    willing to help on more question.
    Sep 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    How do I change the lightbulb in the unit?
    remove the screws holding the outer shell and carefully remove it.... the bulb should be accessable then. make sure the replacement bulb is equivelent to what is in the microwave now. do not operate the microwave without the cover on it. if possible test the bulb before you put it in.
    Jan 17, 2010 | Sanyo EM-P410W Microwave Oven
    F-9 Error on Kenmore Ultrawave Microwave Model 721.64682300
    From everything I have read it is a 1100w inverter, I am having the same problem.
    Mar 12, 2009 | Kenmore Microwave Ovens
    Kenmore Brew 'n Wave 63992/63999 Microwave Oven Logo
    245 people viewed this question
    Top Kenmore Microwave Ovens Experts
    William Miller
    William Miller
    Steve Allison
    Steve Allison
    Jaime Hernandez
    Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
