Question about Samsung YP-T8 Digital Media Player
Problems with hole you place the ear phone
The hole where you place the earphone jack is loose and you do cannot keep the audio connection. The item is brand new less than a month old, but purchased from ebay. Thanks in advance!
    President:
  • 3,130 Answers
The ear phone jack is lose and your gonna need to or have someone resolder the audio jack inside the unit. if you know how to solder then it shouldnt be a big deal once you get the bugger apart. if your not good with a soldering iron, take the unit to an electronic repair shop and there shouldnt be much of a charge exept for minumum beance charge as this is not a major repair UNLESS the jack is ripped out of the PCboard or theres a flex cable connected to the ear jack as thats hard to fix correctly. Good Luck
Posted on May 21, 2006
What can I do about my ear phone jack not working?
Earphone jack ... for changing a tire? Earphone jack on WHAT?
Apr 29, 2017 | Audio Players & Recorders
We lose the speakers when I plug in the earphones. Plugged the ear phones into a single jack because the red white cable did not work.
Plugging into the HEADPHONE jack will always mute the speakers - that is a normal function. If you use the red and white AUDIO OUT jacks you will need to connect them to an audio amp.
May 24, 2011 | Vizio E320VP 32" LCD TV
The earphone jack connection produces sound in only one ear. Partially with drawing the jack produces sound in both ears. Clearly, the jack is not making a good connection once inside its 'port'.
This is usually the result of faulty earphones. Try replacing the earphones you are using with the ipod and it should work normally.
Good Luck!
Jan 13, 2011 | Apple iPod nano
No sound if connected to headset w660i
FIRST OF ALL YOU MUST CHANGE YOUR EAR PHONE.I THINK YOU DONE IT.THEN CLEAN UP YOUR AUDIO JACK USING EAR BUDS OR LIKE THAT.AT THE TIP OF THAT USE SOME ALCOHOL.IF THE PROBLEM REMAINS,YOU MUST CHANGE YOUR AUDIO JACK HOLE/VOTE ME
Sep 26, 2010 | Sony Ericsson W660i Mobile Phone
IPhone 3GS: suddenly music only on the left
hi. i can help you. begin by cleaning out the little hole your ear buds plug into. Carefully clean the jack hole with a needle or a tough pick. It allowed me to remove a lot of cotton like dust. if that doesnt solve it go into your phone menu under audio settings and see if you have adjusted the balance to cause your problem.
also, You can try removing any debris that might be in the headphone jack by plugging and unplugging the headphones a few times.
If the issue is not caused by debris in the headphone jack, request repair/replacement of the Apple Earphones with Mic online here: https://selfsolve.apple.com/GetWarranty.do
You can also request service by making a reservation with a Genius here: http://www.apple.com/retail/geniusbar/or call AppleCare U.S. iPhone technical support at: 1-800-MY-IPHONE (1-800-694-7466)
Nov 10, 2009 | Apple iPhone 3G
EARPHONES NOT ABLE TO PLUG INTO MONITOR.
Hi, I hope you've solved the problem.  But if the first solution does not work for you maybe this one will.
I looked at the specs for your monitor. LINE IN is for plugging in a device that makes sound, so this is not the right hole (called a jack) for the headphones plug.  Look on the back of your computer for a hole that is outlined with light green.  You wrote that you removed " the audio wire that connects the monitor to the CPU", this would be the place to plug in the headphones.
May 21, 2009 | Hannspree Hanns.G HW191D 19 inch...
No ear speaker?
sometimes the phone thinks there are earphones plugged in try plugging earphones in then unplugging again also try volume up and down and it will display earphone on screen keep plugging in and out until it does not say earphone on volume
if that doesnt work restart phone
Jan 16, 2009 | Apple iPhone 3G
HELP ME PLEASE-STEREO PROB.-
I'm assuming that these are not the usualy 1/8 inch jack earphones... are these usb earphones? if so (if using xp) check the settings in the control panel/sound and audio devices/audio tab...then in the "sound playback" section, see if the headphones are given as an option...if so select them and hit okay. Make sure that there are no audio applications open when switching. Hope this helps.
Mar 29, 2008 | Audio Players & Recorders
Shure in-ear phone
I plugged the earphones in another mp3 player and they worked fine. So the interruption of sound must be in the connection between the Mp3 and earphone plug. So the earphone wiring gets a verdict of not guilty. I will do some experiments involving the female plug on the original mp3 player. That is where the problem is.
Feb 12, 2008 | Shure (E2G) Consumer Headphones
EarPhones
several ways.....Wirless headphones that have a small transmitter that you attached to RCA jacks coming out of audio of VCR. You can walk around or sit as far away as you need.
2nd. CONVERTER:: A RCA male plug [ again you conect to back of VCR audio plug] to audio [female] jack [you connect earphones]
Dec 07, 2007 | Sanyo VWM-900 VHS VCR
Samsung YP-T8 Digital Media Player Logo
66 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
