Question about Hotpoint Kitchen Ranges
I have a creda c362e double oven cooker and the main oven does not heat up at all the grill, top oven and hob all still work
Depends on how handy you are with a screwdriver as to whether you want to repair yourself, although it is really basic. First turn off at the wall and remove the shelves from the bottom oven. The rear wall of the oven is held in place by 4 screws and one light cover and the heater element is behind this. Unscrew at the top, unclip from the bottom and remove the wires attached to the back. Test with a circuit tester but does sound like its no longer working. Very easy to order off the net for around £10 if you search for c362e element. Refitting is just a reversal of this. If you are not confident with electrics or if its still under warranty... get out an engineer.
Posted on Oct 05, 2008
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
How to fix creda cooker all of the hobs when put on are unable to control heat
[PDF]Product Directory Summer 2013 - Creda Heating
www.credaheating.co.uk/assets/kb/brochure/.../Creda_Nobo_Brochure.p...
Creda Heating range, installation and operating instructions, brochure ... installations. We are able to offer an expert application design service for all our.
The Different Functions And Uses Of The Oven - Creda ...
www.manualslib.com > ... > Instructions for installation and use manual
Creda J052E Instructions For Installation And Use Manual: The Different Functions And Uses Of The Oven ... For all other types of. cooking, never ... cooking functions are set up by operating the two knobs: ... The oven light turns on and the top and bottomheating ... permit reaching the maximum (250°C) temperature inside.
[PDF]Instructions for Installation and Use - you
Jan 24, 2016 | Creda Kitchen Ranges
Self cleaning mode
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Creda C362E Electric Kitchen Range
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
C362e fan oven stopped heating up fan still works top oven, grill and hob still work.. Had same problem about a year ago, but suddenly started working again before i could get help.... ???
If fan is working o/k, then it is more than likely that the oven element is causing the prob, I would fit a new one under the circumstances.
Please rate my solution.
Thanks.
Jul 14, 2009 | Ovens
Creda grill will not switch to oven when i shut the door
Model Number TGF334BCWF Gas Stove.....When I turn the burner on the top front right my oven is coming on without me turning the on. What is going on?
Feb 21, 2009 | Creda C362E Electric Kitchen Range
Old Creda double oven keeps runing when switch off
sounds simple but look at the knob to see if it is cracked and hence not turning the shaft
Jun 22, 2008 | Creda C362E Electric Kitchen Range
Creda convection oven wont heat up
my ge profile double electric oven, bottome convection wont heat up
Feb 19, 2008 | Ovens
Creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Kitchen Ranges Logo
250 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
