Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Picture The picture on my television is bright on one side of the screen and darker on the other. It is literally half and half. The brighter area seems to have way too much blue. What can I do to fix this? Thanks much.
  • Anonymous Mar 09, 2008
    My Sony is 2 yrs old. It has a bright blue streak that goes form the bottom of the screen up the left side across half the top and then circles down the middle of the screen. It isn't too bad when the picture is light but it really shows up when the move is dark.
  • 1,476 Answers
I believe that the board/chip which controls the LCD is defective. I have never seen this but this is the only thing that I know that would explain your problem. Probably going to need a tech to look at it to verify.
Posted on Jun 22, 2006
SOURCE:
32 inch. on each side of the screen there is a darker area shaped like half a basketball. on each side it covers the screen from top to bottom and goes in a rounded figure towards the center. like half a...
your problem is the yoke of your CRT it not fitted to the picture tube its very far so your picture become like a half basketball..you have to do is fitting the yoke into CRT and then fix it
Mar 05, 2011 | Televison & Video
I noticed that my TV Sony Wega LCD Projection TV picture is darker than before. I tried to set brightness to very high, but still seems to be darker
hello, if you go in to the menu and click on to picture setting half way down the screen is the word reset click on this it should make it brighter hope it works
regards
shaun
Dec 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The screen brightness changes due to plug in or battery power
This is quite common actually I see it a lot. There really isn't any reason, it seems that when on batteries it trys to save power by Dimming Down, but it often just mucks up.. I always now set it via the keyboard keys. whenever I change from power adapter, to battery.
Feb 10, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Screen getting dark
If you have never changed the lamp this is more than likely the issue, as the tv ages the lamp looses brightness. Most lamps are rated for 3000-5000 hrs of use. Replace the lamp assembly part # UX21514 and you will notice a much brighter picture. You do not mention if the tv plays the right colors on the entire screen. These have had light engine issues.
Good luck with it
JOTVGUY
Apr 07, 2009 | Hitachi 50VX915 Rear Projection Television
The picture is not very bright
Good Day;
If this is a rear projection you may need to clean the lenses and mirror and try adjusting the contrast. If it is a direct view your picture tube maybe going soft (bad). If it's a Phillips/ Magnavox change CRT coolant.
Good Luck, big IRISH.
Sep 25, 2008 | Televison & Video
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
My LG 37LC55 LCD TV has one half of the screen darker than the other
Is the XD Demo on. This shows half of the screen with the XD picture engine on and the other with it off. Check your picture settings in the menu.
Good Luck
Jan 05, 2008 | Televison & Video
One half of screen sees darker than other
Problems described are related to Backlight.It is possible that backlights of affected area have become weak.
You may need to contact the company for repairs and Yes the Repairs may not be cheap.
Samir
Nov 01, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
