Servis 1200 rpm machine,water does not drain from machine at end of wash,checked filter and outlet hose,no blockages found.what do i check next
My washing machine does not spin all the water out
Posted on Apr 29, 2010
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Bosch 1200 washing machine will not drain the water ??
The filter or pump is probably blocked, have you tried cleaning it out.
Sometimes if the outlet hose is blocked or kinked this can also be the cause.
Dec 13, 2010 | Washing Machines
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hoover 540 washing machine started making funny noises a couple of loads ago (loud banging noise during spin cycle). Now it goes through whole cycle but when it gets to 'drain' part of the cycle,...
Sounds like a blockage in the outlet pipes or filter. It may be possible to drain it if you can get the outlet pipe (one from back of machine) outside, lay it flat on the ground as this will take it below the water level in the machine and may slowly drain. Once it drains out enough the machine should disengage the door lock to allow you to open it. Then check your filter and pipes for blockage. If no blockage is found then suspect faulty pump.
Jan 25, 2010 | Washing Machines
Will not drain
To have the washing machine drain properly you would need to do the following steps:
Open the case, and disconnect the water hose from the outlet of the water pump.
If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
Next plug back the washing machine.
Thanks for contacting fixya.com
Nov 26, 2009 | EuroTech EWF172 Front Load Washer
Magtag rpm 1200 front loader taking water ok and washing but not draining? (there is no kink in hose and i nothing in filter?)
Not draining mostly due to blockage, can also be pump or electrical feed to pump/if you have multimeter and can use easy to find out which, check sink drain just in case..
Nov 04, 2009 | Maytag EPIC MFW9700S Front Load Washer
When rinsing/spinning the water comes out of the dispenser drawer
I see this is under the dryer section, i am assuming its a washing machine or washer dryer.
If its leaking from the dispenser during the filling stage, this could be a blockage in the dispenser or as simple as the water pressure is too high,
If it leaks during the spin on the rinse cycle, this is generally a blockage on the outlet area (normally the sump hose/filter) remove the filter if fitted and check for blockages, if ther is no filter on this appliance, you will need to check the sump hose, this is located under the machine, mormally a black hose from the tank to the drain pump, remove from the tank end and look in there, Finally it could be a blockage at the end of the waste hose (grey one) it quite often gets blocked at the sink end.
Hope this helps.
Regards
Sussex engineer
Please rate my help. Thanks
Oct 22, 2009 | Hotpoint Dryers
Washer won't drain water during wash cycle i have to do it manually i've checked for blockages but can't find any
Please follow the steps provided bellow :
Fill washer with water and wait for the timer to get to the drain mode.
Unplug the washer from the electric outlet.
Reassemble hose from step 3.
Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Reassemble washing machine case...you're done...
Thanks for contacting Fixya.com
Aug 16, 2009 | Tricity Bendix AW1400W Front Load Washer
At the end of the cycle the water is not draining out of the tub. I vac'ed out the water, removed the filters and checked for debris but found non.
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump (not switching from recirculate to drain) , a wiring problem, or a faulty timer board can be cause the machine not draining.
May 06, 2009 | Bosch SHV46C03 Built-in Dishwasher
Washing Machines Logo
802 people viewed this question
Top Washing Machines Experts
