I have a Lexmark Prevail Pro 705, coping and fax sending will leave a 3/4 inch line on the edge of the page (right side if using flatbed left side if using doc feeder. Is this a misaligned mirror?
could be the document size or not enough memory or if you are printing from a network could be network traffic... try deleating the current driver software and reinstall the new software using the disc that came with the printer
Make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update. It helps maximize the life of your ink cartridges.
You need to change the mylar strip on the ADF and also you need to clean the narrow strip of glass that the scanner uses for ADF scans. The Mylar strip is found by opening the lid, as you do when you put a document on the glass. On the left side you will see a Mylar sheet that covers a white backing section. There is a latch on the front and back of the Mylar mount that allows it to drop down. There should be spare Mylars in an envelope tucked under right edge of the white backing strip for documents placed on the glass. Just be sure to orient the new strip the same as the old one. The mylar strips can sometimes be cleaned but usually it is better to replace it if you have spares.
Hi , Go to google and type in make and model , it will bring up a page with what your looking for , ebay is a good source to .......................Roy
Check the settings of your printer, either in the software that came with it or the printing preferences in the Control Panel. If your ink tone is set too dark, it could be using a lot of ink. If this is not the case, then:
1) Clean the ink cartridges 2) Replace the ink cartridges as they may have expired.
3) Replace the printer and find one which uses cartridges that can perform more copies in a single fill.
This article on How to Troubleshoot the Vizix Ink Technologywill help fix print quality problems on your printer. To run the Deep Clean Printhead function on your printer -> on the printer operator panel, press Setup -> Maintenance -> select Deep Clean Printhead. Your printer will then print the test page. Hope this helps. Thanks.
