Question about KitchenAid KSM5PS Heavy Duty Stand Mixer
Motor runs, but beater doesn't turn
My KitchenAid is 15 years old and I am about 300 miles from a repair shop. Is there any way to find a schematic so I can attempt to repair my mixer? The motor runs strong, but it no longer turns any attachment. I am guessing a gear has finally worn out, but I cannot figure out how to open the casing or how to find the challenged piece. Is there a way to get a schematic to see if this is fixable before I buy another?
  • 7 more comments
  • Debi Rubera May 21, 2006
    Thank you so much! It has been such a work horse I could not believe it could not be fixed.
  • Pyski Dec 03, 2007
    We have the same problem. It is a wonderful machine, but I have to wonder if we should fix it or just look for a reasonably priced used one, or just go with another brand completely because the price is prohibitive right now.
  • gwick Dec 08, 2007
    The beater turns ok until It hits the batter then it goes real slow.. then stops. Could this be the motor or gears? Thank you in advance..
  • townsendl Dec 28, 2007
    Our 15 year old Kitchen Aid mixer has stop working correctly. THere is no speeds, I just move the speed selector back and forth until it hits a spot and will turn on, and it only goes Fast. Help , what do I need to do to get into it and figure out what needs to be repaced? Thanks
  • Anonymous Feb 19, 2008
    I have the same problem, but my mixer is not old. It is only 3 years old it is KP26mixmr. I don't know what parts to order to fix it.
  • igoofed Mar 08, 2008
    the cover to the grinder attachment fell in the batter and now the beater does not turn. The mixer runs, but does not beat.
  • Anonymous Apr 13, 2008
    motor runs but the beater unit doesn't turn.
  • Juanchi May 21, 2008
    I have a similar problem whereas the mixer will stop at a particular point in the orbit (280 - 290 degrees / 0 degree being the front) under any kind of load (i.e.: not empty). A nudge will make it start again and it will go around just to stop at the same point in the orbit. Any suggestions? I wouldn't mind fixing myself but not sure where I can get a repair manual and parts.
    Cheers,
    Juan
  • judyws Feb 16, 2009
    My Kitchenaid Mixer KSM90 seems to be worn out. The motor runs but the beater doesn't turn. We are a long way from a repair center and there doesn't seem to be anyone in our area that does small appliance repairs. I suspect a gear is worn out but don't know what to do. Thank you.
Ok, do you want to know how to disassemble? i just inherited a kitchenaid mixer from my brother and it had the exact symptoms. First, using a hammer and pin punch, drive out the pin that holds the beater mechanism. Pull off the mechanism and remove the chrome ring that is above it. You will see about 6 screws under there, remove them. Next remove the 2 screws at the opposite end of the bottom of the motor housing. Now carefully and evenly separate the motor housing. The motor will come off completely. Lay the motor aside being careful not to pull the wires too much. you might want to support it with a box or something to rest it on. Ok now you will see a bunch of grease on the gears. Put the grease in a paper cup as you will need it again. Wipe off the gear assembly and examine the teeth on the gear. chances are there is a spot where there is no teeth at all. Replace that part, put the grease bak on the gears and reassemble in the reverse order. I did mine in no time, just pay attention to what you are doing. The chrome ring is a little tricky to get it back on but it will stay if you keep trying. You might have to roll it against a hard surface to bend it inwards to make it fit tighter. Good luck and let me know if this helped you out!
Posted on Aug 03, 2007
The mending shed has the KitchenAid_Service_Manual.pdf available and sells parts. http://mendingshed.stores.yahoo.net/kitaidparts.html This allowed me to replace the pin that had fallen out of the gear. Mixer was making a clicking sound and then when the motor ran the beater did not turn.
Posted on Oct 02, 2006
    President:
  • 3,130 Answers
Yes Debi that is an oldie but a goodie!!! Your problem MOST likely is the gear assy mechanism. The part # is 949544 and cost about 38 or so bucks.. Now you can go to http://www.repirclinic.com to order parts or call them for assistance as they are really helpfull and you may also get to speak to someone who can tell ya how to take it apart. If not then leave an email on the site for the tech.. The # is 800-269-2609 Good Luck
Posted on May 20, 2006
4 Suggested Answers
SOURCE:
SOURCE: Beater does not turn
It sounds like the nylon gear is stripped out. It is a rather easy to replace and also inexpensive. A gentlemen posted a step by step site to replace the gear. The link is http://www.neilcrockett.com/mixer.htm
Good Luck
Posted on Dec 07, 2008
ricardok45
  • 135 Answers
SOURCE: KitchenAid KSM5PSGR Stand Mixer - attachments not turning
Hi Gail. Kitchenaid no longer has a Parts List for your model. This means that they consider it obsolete. Do an Internet search for parts. You may get lucky. Good luck!
If this solution has assisted you, please rate it. ricardok45
Posted on Apr 04, 2009
SOURCE: How do I Open Up a KitchenAid RRK150 Mixer?
you have to take the pin out from right above where you put the beaters on, and then you can tap the circle part off, and get into the inside...
Posted on Aug 10, 2009
The mixer runs but the beater doesn't turn. Drive shaft?
a gear or gears. their usually plastic and will damage before the drive shaft
Feb 07, 2013 | KitchenAid K45SS Classic Stand Mixer
I can't get the beater released from the shaft. I did exactly what the book said, push up as far as it goes and turn to the left, but it doesn't seem to go far enough.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Constant pushing of the beater onto the Agitator shaft (40) can cause
it to be pushed in too far into the Planetary (33). With the beater in place,
use a rubber mallet to slightly tap the edges of the beater and push the
shaft out until you can see the retaining clip.
Now you have enough clearance on the shaft to push the beater upward
and twist it to remove it.
Aug 05, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Beater won't turn, but motor is running.
Hi, Did you push the beater in so that it clicks. If all is good there, gear box maybe at fault or jammed. Take it to a service center for repair. If you are machanicly inclined (DIY) Take it apart and see why its not turning. Good luck.
Jun 04, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Beaters will not move
You have probably stripped a gear in the gear housing. Here is the breakdown of the gearbox:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
The newer "more improved" mixers use plastic gears and they can't take the beating, no pun intended, and fail.
The good news is that the most likely gear to fail is cheap. Here it is on amazon.com:
http://www.amazon.com/KitchenAid-W10112253-Worm-Gear/dp/B0006HLAVA
http://www.misterfixit.com
Mar 25, 2010 | KitchenAid KSM150PS Artisan Series Stand...
My kitchenaid ksm150ps standing mixer's top seems to tilt down too low and bounces up and down when mixing
Hi DENISE, by the symptoms you describe it appears that it’s time to adjust your mixer’s Beater to Bowl Clearance adjustment screw, or head locking mechanism (or a component) of it is worn or loosened due to normal wear and tear and needs to be readjusted (or repaired) to keep your mixer head stationery and level.
The instructions for adjusting your beater to bowl clearance are located in your Owners Manual. If you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66) KSM150PSER1.pdf (732.33 KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height.
But to save you some time, I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
If the above doesn’t correct your problem, then you need to look at the Link & Lever Latch assembly. If you don’t have your parts list manual, select the file KSM150PSWH0.pdf (773.44 KB) listed under the Parts List Manual (61).
The manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part names and numbers. Turn to page5, titled: Base and Pedestal Unit. You’ll want to focus on Illus. #11, Link & Lever Latch assembly, and the related components, which locks the mixer head to the pedestal when you run the mixer. Check to see if something is just loose, exceedingly worn or broken. If something has broken, you can order replacement parts and install yourself.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Also, while your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your KA mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, repair, and reassemble your mixer.
Finally, if you feel this is beyond your capabilities and will be too difficult to do by yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! – hslincoln
Dec 23, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I have a Kitchenaid Professional 5 Plus Mixer beaters won't turn
It sounds like it has been overloaded and the worm gear has been stripped. You will need to take the head apart to confirm this.
Jun 24, 2009 | KitchenAid K45SS Classic Stand Mixer
Motor runs but Beater shaft does not turn
Hi guys. Kitchenaid does not publish a parts catalog for your KSM90's. Your best bet would be to take it to a small appliance repair place and get a quote to repair it. They may have an old catalog for parts. Try to find a place that has experience with KSM90's. Kitchenaid has left you twisting in the wind, like many,many others. Without these parts drawings, self repair is iffy at best. "For the way it's made"! Indeed. Sorry! I wish I could help more.
Mar 29, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 250 Watts; Classic: Leaking Oil
Found this,may be helpful.
Why do I see oil leaking from the beater shaft of my stand mixer?
Some KitchenAid® stand mixers that are not used very often or have been tipped may experience slight oil leakage from the shaft or hub attachment. To avoid the oil leakage, KitchenAid suggests that you run the mixer weekly for short periods of time. Generally, the mixer may lose approximately X cup of oil before repair is necessary. The oil used is FDA approved and is not harmful to consume, should any get into the food that you are preparing.
Dec 15, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM90 motor runs, but beaters don't turn
I feel your pain. I own a new Kitchenaid, and for some reason they changed some of the metal gears from metal to plastic on the newer models. I suspect it was to make it quieter. But they strip out. Happily, the replacement gears they sell are metal, and once replaced will last a lifetime.
You will either need to replce them yourself, of find a repair shop.
Aug 07, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
740 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
