Question about Apple iPod nano
IPod nano (2nd generation) 4GB
Today when i press the play button it hang & screen is same on that play position, the light of the screen still glowing no sound no functionlaty is working whn i pressed the buttons... wht to do.. plz let me out from this....
    Genius:
  • 1,673 Answers
Generic answer for most devices of this type:
Check in the instruction book if there is a way to do a full re-set. If this is not the solution, remove the battery for a few minutes and then re-install it.
I know that there are some issues with this type of product. You may have to send the iPod back for service. If the unit is out of warranty, it may not be worth to service it.
Jerry G.
Posted on Sep 13, 2008
Got a new ipod nano 5th generation today. I plugged into the computer USB to charge it and it says loading briefly.....then goes to an all white screen and won't do anything else. Is this normal? Is it...
Hi! Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thank you for using Fixya!
Nov 19, 2010 | Apple iPod nano 5th Generation
This watch is compatible with ipod 5 generation 8 GB
This watch is compatible with iPod 5th generation (video); iPod Nano 2nd generation (aluminum) 2GB, 4GB, and 8GB; iPod 5th generation (video) 60GB and 80GB; iPod Nano 1st generation 1GB, 2GB, 4GB; and the iPhone.
Feb 08, 2010 | Timex Ironman iControl Watch with iPod...
Pink ipod 8GB frozen on language screen
just try to reset you ipod by pressing play and menu button simulaneously for 5 seconds and it'll restart then again if it's hanging there hold play button during bootup then enter bios mode from there u can connect to pc n restore the software
Jun 09, 2009 | Apple iPod nano 3rd Generation
The unit will not turn on nor charge.
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 20, 2009 | Apple iPod nano
Volumn locked on ipod nano 4gb third generation
Press and hold down the center button while pressing on the menu button.
This will reboot your IPod.
Jun 21, 2008 | Apple iPod nano 3rd Generation
Ipod 2gb hanged
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)ipodg1-2.gif ipodg3.gif
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Dec 19, 2007 | Apple iPod MA446LL/A MP3 Player
Not playing all of the music
  • iPod classic
  • iPod nano
  • iPod mini
Dec 08, 2007 | Apple iPod MA446LL/A MP3 Player
Apple ipod
  • iPod classic
  • iPod nano
  • iPod mini
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
My ipod was hang!
ya just hold the menu and center button till an apple image appears on screen!
Nov 13, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
42 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
