Question about RCA T13062 13 in. Combo
Tape Loading Error
When inserting tape, player accepts it. After pressing play button, vcr screen shows "play" but does not play but shuts power off. Upon resuming power button "on" tape ejects. Have used various commercial tapes.
    President:
  • 3,130 Answers
Theres a loading problem with the mechanism. It could be a nylon cam thats cracked and thrown it out of mechanical alighnment??? this is not for the handy man repairer!!! this should be taken to a repair shop for an estimate! as there are hundreds of volts inside a tv that can cause you to be seriously killed!!
Posted on May 21, 2006
My VCR/DVD combo wont play a VHS tape when inserted. Each time I insert a VHS tape, it shoots it right back out and sometimes unravels the tape around the apparatuses inside the VCR. It won't reco
the tape coming back out and unravels the tape means the loading mechanism is the problem----when a tape goes in it loads the tape down, then it pulls the tape out of the cassette and puts it up against the drum with the video heads-----many of these are belt driven and a bad belt or belts will cause this----it is called the loading and or transport mechanism.......when it fails the arms come back but the tape does not get rewound back into the cassette so it mangles it when the cassette door on the tape closes----most likely a belt or the drive idler which also rewinds and fast forwards the tape.
Oct 16, 2012 | Philips Magnavox DVD/VCR Dual Player
VCR player won't play
You might want to buy a tape cleaner...what exactly happen when you tried to play the tape?
Apr 16, 2008 | Televison & Video
I have the Philips DVP3150V/37 DVD Player / VCR Combo. The DVD player works fine, but when putting in a VCR tape, it plays for a few seconds then shuts itself off. Any suggestions on what to to?
The 3150 has two belts or bands that can slip when old, just like the old days. One is for loading the cassette and the other is for providing take-up torque for the tape. Have also seen the tape loading arms get out of sync and don't put the tape around the heads..... working on one now but dont have a fix yet..it has the loading problem.
Nov 01, 2011 | Philips DVP3150V/37 DVD Player/VCR
How many motors are in the VCR section? example 1 motor for play, 1 motor for hi-speed rewind, 1 motor for hi-speed forward.
There are only 2 motors on the VCR sections.1 motor for the rewind backward and speed foward.1 motor for take in the VHS tape and eject the tape.The play button also used the same rewind backward and speed forward motor to push the film foward to the VCR play head head drums to play the tape.
Nov 24, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Sansui DVD/VCR remote control issue, VCR works/DVD does not-black
There should be a DVD/VCR button on the remote control which will toggle the machine from one playback source to another. If she has pressed the VCR button then the machine will only playback tapes & not show DVD's. Press this button & the DVD's should play. If you look closely at the front window of the machine it will show what mode it is in ie VCR or DVD, set this for the DVD to get it to play.
Sep 16, 2009 | Sansui VRDVD4000 DVD Player/VCR
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
F08 Error message, keeps shutting down
Get it to a shop. The error is a drum servo related problem. Don't force the mechanism or you'll be out even more...accordianman
Feb 15, 2008 | Panasonic AG-DV2700 Mini DV VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Vcr jam
You really should take this unit into a repair shop with the stuck tape as to get this bugger out of the unit will require the tape loading mechanism to be disassembled. if this is not taken apart correctly, you could cause more damage to the unit. Good Luck.
Apr 08, 2007 | GoVideo VR2940 DVD Recorder/VCR
VCR Tape will not play, it keeps ejecting
I have a similar problem. It takes 3 or 4 times to get my Sony VCR to accept a tape. Once it does, everything is fine, until I turn it off. Next day, same trouble. I tried several tapes and brand new tapes. No difference. I have opened the cabinet and used alcohol to clean various stuff, no change.
Feb 02, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
RCA T13062 13 in. Combo Logo
78 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
