Question about Singer 7462 Mechanical Sewing Machine
Singer Confidence 7470 does 3-4 stitches, then beeps and stops
Brand new out of the box. When we press the pedal the machine does 3-4 stitches and then stops and beeps twice. There are no errors and if you press the pedal again it does the same thing. I have read multiple posts and the button hole lever is up. Any suggestions? I do see a few other posts with a similar problem.
  • 1 more comment
  • jreynoldsdes Sep 24, 2008
    i have the same problem....please help!
  • Anonymous Feb 06, 2009
    Any one? Same problem here
  • Kalpana Reddy
    Kalpana Reddy Aug 15, 2017
    Did u get resolve this problem
  • 46 Answers
Ring up or go to where you bought it from. They should be able to tell you.
Posted on Oct 24, 2008
I have a Singer Confidence 7469Q Sewing Machine. It just stopped sewing, makes a beeping noise when i push foot pedal. Can you please help me? Thanks
Something is not in the correct position to sew...perhaps the presser foot is not down, the feed dogs, etc. Check to make sure you do not have a stitch (like zig=zag) selected that the presser foot or needle plate cannot accommodate.
Jul 31, 2017 | Singer Sewing Machines
Singer conferdence 7470 not sewing
Try a brand new needle. If that doesn't work, then the machine is most likely out of time. Search for sewing machine timing or take it for service.
Feb 13, 2017 | SINGER 7470 Sewing Machine
Hi, I have a singer confidence 7470 sewing machine and the needle keeps hitting the bottom of the bobbin. I need to know how I can adjust the needle.
Try a brand new needle. If the old one is bent, that could be why it is striking. If the new needle doesn't resolve the issue, the machine most likely has a timing issue. You can search for multiple web sites and videos for discussions and instructions for sewing machine timing issues. Or you can take it for service.
Oct 04, 2016 | Singer 7470 Confidence Sewing Machine
When you push foot pedal c3 comes up and beeps 3 times
Don't know what machine you have, but this may help:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwigsLfzlJbKAhVB7WMKHYHZAHwQFggdMAA&url=http%3A%2F%2Fwww.singerco.com%2Fpdf%2FFC_Plug_In_Instructions.pdf&usg=AFQjCNEqPAnJbHodHAqfFC95mKH913qZVA&cad=rja
Singer One Instruction Manual Helpful Messages
Error code & would not sew after 2 uses.
4/19/2012
Customer review by DeZooMT
1.0 stars by DeZooMT
Got this as a Christmas gift. Have used it twice since then for little things. Seemed to be fine. Decorative stitches worked and the straight stitches turned out good too. But didn't last. Just took it out to use on a bigger project and it just stopped sewing. The foot pedal wouldn't work at all. The back stitch button would sew though. If you tapped the pedal aggressively at times it would delay and then jump forward 3 stitches and then display the C3 error code saying the foot pedal was disconnected, which it clearly wasn't. Tried the Singer CS line. Was caller number 20, was on hold for 40 mins when I finally got down to caller number 4. All of a sudden the operator hung up the call and stated "their offices are now closed." I was furious. Needles to say, it went back to WalMart and I won't be buying another one.
Jan 06, 2016 | Sewing Machines
My brand new Singer 7463 will not sew, even though the lights, stitch settings, and everything else are completely fine.
The foot pedal is just a variable resistor to give you speed control of the motor
You say the machine is new so it will still be under warranty
have a service technician check it out
It could be a faulty control pedal or leads or motor
Aug 04, 2015 | Singer Confidence 7463 Computerized Sewing...
E2 error code brother sewing machine
A stitch other than the buttonhole or bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Note Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operationOne beep is sounded.
  • If an incorrect operation is performedTwo or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangledThe sewing machine continues to beep for four seconds.
    The machine automatically stops.
    Be sure to check for the cause of the error, and correct it before continuing
Jan 11, 2014 | Sewing Machines
Difficulty reinstalling needle plate in Singer Confidence 7470
Look at page 80 of your manual.
There's a little finger on the left of the plate that fits in the corner.
Dec 02, 2012 | SINGER 7470 Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
350 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
