Try resetting the base idle,disconnect the battery,leave for ten minutes,reconnect the battery,start the car and do not rev the engine for ten minutes.hope this helps
a common problem on the gdi engine is carbon build up on the valve seats resulting in poor idling,the repair for this is to remove the cylinder head and clean the valve seats,but a mitsubishi garage has a tool which saves removing the head,saving a lot of time and money,the procedure is called a carbon blast,although without checking the car personally i cant say that this is definately the fault,just a common one
Can you tell me what position the 4x4 gear stick should be in,when driving in day 2 day weather conditions, ive got it in 2w at moment is this right, the green light is flashing.
I want to know what tonnage a pinin 2L cand tow 2005 model Thanks
Tried adjusting idle control unit. Fingers Crossed, this appears to have achieved Good Results. Many thanks for your help.
when i start my 2000 mitsubishi lancer gdi engine it revs up and sometimes im at a stop and it gives me a push then dies down
