Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
Sata drive not seen by mobo?
I recently bought a sata drive, but when I tried to install it along with a pre-existing ide drive, it doesn't seem like it's being seen by my motherboard (asus m2n-e sli) at all. Thinking that this had something to do with the IDE drive, I unplugged it and tried to install Windows afresh on the sata drive, but it said something along the lines of no harddrive was found.
I took at look at the BIOS main menu (screen in pg 4-15 in the manual), and the sata drive isn't listed there either, whether if I had it plugged in by itself or with the IDE drive.
I'd really appreciate it if anyone had some ideas that might help me.
Thanks
    Genius:
  • 1,689 Answers
On some older models of mother boards, you cannot use the SATA drive as a main start-up drive. You can only use a SATA drive as a data drive if this is your case.
To verify this, re-install the IDE start-up drive. When the computer starts, verify that you can have access to the SATA drive as a second drive.
I have this issue with a few computers at our facility.
Jerry G.
Posted on Sep 13, 2008
Cannot find hard drive
If your trying to install an operating system on SATA then you will have to press "F6" at the beginning of the installation so you can install the SATA drivers.
If the IDE isn't being seen then go into the BIOS and see if it is recognized.
Sep 28, 2009 | Intel CompSource X-Treme PENTIUM 4/P4...
Secondary IDE channel
the motherboard you have can only support 4 SATA Drives. if you want to use your IDE drives, you have 3 options: 1) buy a SATA to IDE Converter which is around $20-$25. (if you selected this, you can fix the drives into the internal of the pc). 2) buy USB to IDE converter $10-$15. (if you want to fix the drive inside the pc, remove one PCI slot casing cover at the back of the computer casing and use the USB slot at the back of PC). Hope this helps. Good Day!
Jul 06, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
SOYO KT600 Dragon Plus mobo not recognize WD Caviar SATA 1TB HDD
Yuck! Soyo filed for bankruptcy in May and their website is gone!
You need to enable the SATA in the rom bios AND install the drivers for it; but, I hope you have the manual and the CD.
Jul 05, 2009 | Soyo Computers & Internet
Instalation of ad on IDE/SATA PCI card
You have to set one of the DVD as Master end the other as Slave if they share the same ribbon connector. Do this simple test: let only one of the DVD connected. If the PC "sees" this one, then the card is OK. If need more instructions, just post a comment.
Apr 16, 2009 | Computers & Internet
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
How to use/add sata on my mobo?
You need to add a controller card for SATA. These are not expensive. One you might consider is this:
Vantec UGT-ST200 Serial ATA PCI Host Card
It costs about $25, and is available many places, including Tiger Direct, Fry's Electronics, and others. Here is a link to one on the Fry's website. Shop around, you might even find it somewhere else cheaper:
http://shop4.frys.com/product/4236634?site=sr:SEARCH:MAIN_RSLT_PG
Once you install the card in an empty PCI slot, you install a new SATA hard drive, and cable it to it. It should work fine with your existing PATA drive(s).
Cheers
Nov 13, 2008 | PC Chips M848ALU Motherboard
Install hard-drive
Sata drives don't have an option to be master/slave like IDE drives, b/c the Sata cable is per device. If the computer's not pulling up the sata drive, open device manager (right click  my computer, properties, hardware tab, device manager) and look for a yellow question mark. You'll have to install drivers for it more than likely.
May 16, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
88 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
