Question about Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11)
Toubleshoot I got three wifi switches in the same floor of a builiding at an average distance of 25 meters. All the three switches are having the same resource (ie all the three are providing internet connection sharing from a modem). The acces to the wifi by PC is controlled by pass words. Now the problem in detail. The swith which is catering for two PCs is intermittently showing no connectivity to the network. When we chek for availble WIFIs in the PCs having trouble, they shows all the 3 WIFIs available in the area. On selecting the correct WIFI the problem gets rectified and re occurs after some time. What could be the problem? And how the problem could be solved permanently
    Scholar:
  • 32 Answers
My guess would be a networking problem where the two PCs can see all three access points and are getting confused. Perhaps getting a DHCP license from one of the other access points and then trying to use that, conflicting, IP to access the access point you want. If the PCs are fixed, you could always use three different SSIDs to prevent this from happening.
You don't mention it but you should have all three access points on different channels that are spread apart to minimize interference. Try shutting off the other two access points, right clicking on the network icon on an affected computer and selecting repair. If you can get on the network after this, then my solution will fix your problem.
You might want to consider switching to a solution designed for having multiple access points on one network. Open-Mesh is a pretty good inexpensive route and you can add multiple access points easily. The firmware is still in beta, however, I have a network of 5 nodes that is pretty reliable. If you want a more commercial solution, the Meraki network (the predecessor of open-mesh) is very robust but more expensive.
Posted on Sep 13, 2008
Note 2 wifi weak wifi signls. it works only if i go near to router distance between 3 meter
Bad router or it may be the wifi card in your device? I have a router that the wife's laptop cannot connect to very welll from 18 metres away. The guy down the road can logon to my network from 40 meters distance.
Maybe it is not the router.
Try replacing it with a newer model, the lifespan of a router is probably about 2-3 years before they start degrading. Check reviews for recommendations as to which has the best signal strength/range
Jun 11, 2015 | Computers & Internet
There are two adjusting screws on the buick century headlights, which is the horizontial screw
ADJUSTMENT PROCEDURE
Complete the following steps and refer to the accompanying illustrations in order to adjust the headlamp aim:
1. Ensure that the headlamps are a distance of 7.6 m (25 ft) away from the wall.
2. Mark a vertical line on the wall. Align the vertical line with the center line of the vehicle.
3. Mark a horizontal line on the wall. Ensure that the distance of the line to the floor is equal to the distance from the center of the headlamp aim dot to the floor.
4. Using the following components, ensure that the following specifications match the specifications in the illustrations:
^ The headlamp aim adjusters (1).
^ The zero set access hole (10).
^ The zero set meter (11).
Feb 21, 2015 | 2001 Buick Century
How to calculate coefficient of variation on TI-36XPro
As given in part three of the question, divide the standard deviation by the average then multiply by 100.
Sep 20, 2014 | Texas Instruments TEXTI36XPRO TEXAS...
I have a d-link 2750u wifi router with dual atntena..but connect in my badroom its near by wifi router i fonna show you in video with distan
Hi
Thanks for the video. I appears that you have concrete floors in your home. A couple of things that drasticly reduce wifi distance or signal strength is electrical fields caused by wiring in the walls and concrete walls or floors. Concrete is very dense and also has a lot of metal rebar in it for structural strength. This combination is very tough to penetrate with radio signals. The best thing you could do is either mount the router higher in the first room you showed so that it is at a level about even with the floor of the second level or add a repeater somewhere on the second floor. Mounting the router higher allows the radio waves to bounce around both levels without having to go through the concrete and rebar between them.
Jun 13, 2014 | Computers & Internet
A train leaves Middelburg at 09:00 and arrives in Johannesburg at 11:00 having traveled a distance of 180 km. Find the average speed of the train in m/s.
Journey time 2hrs = 2 x 60 mins = 2 x 60 x 60 seconds
Distance 180 km = 180,000 m
Average speed = 3 x 6 x 10000 / 2 x 6 x 6 x 100 m/s
= 6 x 6 x 100 x 100 / [2 x (2 x 6 x6 x100)] m/s
= 100 / 4 m/s
= 25 m/s
5.May.2014
May 05, 2014 | Office Equipment & Supplies
Meters to square meters
Square meters defines surface area therefore you have must have two meter distances that can be multiplied. Example: To determine the surface area of a room floor measure the length of the room (3 Meters) the width of the room (2 Meters) = 3x2 meter = 6 square meters
Nov 21, 2013 | onlineconversion.com
I face a problem to connect a to office with a 95mtr cat5e cable.switch is not blink on both hands.
95 meters is simply too long. No way of getting a signal on the other end without the use of a repeater. The maximum distance for CAT5e and CAT6 is 295ft, which is roughly 90 meters, but even that only works in an ideal environment. Often the max distance is announced with "300ft = 100m", but that is not true (and 300ft are only 95 meters anyways.)
The best option is fiber optic cable, but that is very expensive.
Read also this article - it has some good explanations and comments.
I would buy a cheap router (WRT54G i.e.) and modify it with some third-party firmware as repeater. That would cost you not more than 25-50$. (Tip: google "Router as Repeater", and you will find many results.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jun 01, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
What are the flash metering modes?
The DiMAGE A1 employs three metering modes; ADI (Advanced Distance Integration) flash metering, Preflash-TTL metering and Manual. The ADI flash metering mode combines distance information from the autofocusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, 1/8, 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash will not burst.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11) Logo
116 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
