Kyocera Finecam S5 Digital Camera
Problem for Kyocera Finecam S5 Digital Camera
Camera tries to start but lens will not open
By Kay-UK on May 20, 2006
After using the camera last Satuday, I got it out on Thursday and suddenly it would not start up properly. It tried with rapid click, but the lens will not extend and the flash is partial up. Help please. It has not been dropped and lives in my handbag!
Comments:
May 21, 2006
- Yes, I left it charging for 24 hours, and checked the charge light was green.
I have just put the battery back it after leaving it out for 24 hours, and with a little very gentle persuasion, the lens has opened, it will zoom in and out, but when it shuts down the flash does not now go down, and unless I turn it onto review before I switch it off it turns back on again. The lens opens now when I switch it on
Same Problem
May 01, 2008
-   My daughter tipped the camera over. At first the lense would not go in. My husband followed the advise and gently moved so that the lense would retract. NOW it won't open. It just makes a buzzing noise! HELP!!!!-   msbuckweet
Dec 28, 2007
-   MY KODAK C603 DIGE. CAMERA ,THE ZOOM LENS WILL NOT EXTEND OUT WHEN I TURN IT ON-   woodsy777
Dec 04, 2007
-   My Casio Exilim tries to start (makes beeping sounds) but lens does not move. How do I reset it?-   YvetteR
Nov 13, 2007
-   My camera is almost two years old. One day it randomly stopped working. The lens does not open and it makes a grinding noise. The screen appears but nothing happens then it goes black and flashes error code 011. I've been trying for months to fix this and nothing works. please help!-   leesh
Solution #1
posted on May 21, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3620 votes
have you checked the batteries are fully charged ? Are you using nimh batteries? did a reset?
Might be obvious, but since you don't mention it, I should ask.
Was this helpful?
Yes
No
Solution #2
posted on Jan 10, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hi there~
I don't know if this is any help any more, but it's probably a mechanical problem. I babied mine too and the same thing happened.
If you lay your camera flat and look straight down at it, you'll probably notice the gaps in the zoom thing (sorry, i don't know the techincal term for this) are not the same all the way around. If you *gently* push the lens on the 'fatter width' side and even it out, the camera should be able to open.
The other possibility is that there is grime in those gaps, and tapping your camera gently or using one of those canned air dusters should get it out.
I really hope this is a little more useful to you!
Popular Solutions for Kyocera Finecam S5 Digital
Questions and Unsolved Problems for Kyocera Finecam S5 Digital
Do you recommend Kyocera Finecam S5 Digital Camera?
Answer
Answer
The camera won't turn on all the way. The screen lights up, but the lens does not extend.
Answer
Finecam S5 will not take pictures or video. It will not display subject on LCD screen. All other... (More)
Answer
the camera switches on but you can't see the pictures or the video you shoot, in fact you cant see... (More)
Answer
Where can I get a pdf manual of Kyocera Finecam S5?
Answer
My Finecam s 5R displays unsupported format on the screen and will not take photos. Have tried... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
