Question about Casio FX-115ES Scientific Calculator
Exponential Functions in the center of a circle 9ft. in radius is a frog. it begins to jump in a straight line to the circumference of the circle. its first jump 4 ft. 6in., its second 2ft.3 in., and it continues to jump haft length of the preceeding jump. how many jumps does the frog make to get out of the circle? How can i do this exponential function for simple process?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 98,921 Answers
A classic. This is one of Zeno's Paradoxes.
Posted on Jun 07, 2012
2 Suggested Answers
  • 10 Answers
SOURCE: subtracint measurements
just convert the inches to decimals (12ths) approx. .08333
Posted on Mar 05, 2009
What is the area of a circle if the circumference is 2 pi inches
area formula is PI x r squared
that is 3.1417 times the radius of the circle squared
example is:- 3.1417 times 3 inches squared =3.1417 times 3x3=3.1417x9=28.279 square inches if you want to work back from a circumference measurement, the formula for circumference is 2 x PI x radius or PI x diameter
if you have a circumference of 12 inches then the dia is calculated 12 inches = dia x PI to get the diameter , divide the 12 inches by PI and that will be the diameter so that is 12 divided by 3.1417 =3.819 inches
now you can go from the first formula the radius is the diameter divided by 2 so the radius will be 3.819 divided by 2 = 1.909 inches
so applying the area formula it becomes 3.1417 times 1.909 times 1.909 =11.458 square inches
to find your answer simply substitute the dimensions in place of the example figures.in the relevant formula.
Aug 24, 2015 | Office Equipment & Supplies
What's the measure of an arc if it's central angle is 35 degrees?
Assume the central angle is 35 degrees and the radius is 1.
The circumference of the whole circle is 2 x pi x radius. Since the radius is 1, the circumference will be 2 x pi.
Now a full circle is 360 degrees.
Now we can set up a ratio of 35 degrees is to 360 degree as x is to 2pi.
35 x
360 2xpi
Cross-multiply and isolate your variable.
Good luck.
Paul
Mar 25, 2015 | Office Equipment & Supplies
Formula for circumference
Circumference of a Circle: 2 x pi x radius - OR - pi x diameter,
or if you need some sphere calculations?
Sphere Surface Area: 4 X pi X radius squared OR
pi X diameter squared Sphere Volume: 4/3 X pi X radius cubed OR
( pi X diameter cubed ) / 6
By the way.......... "pi" = 3.1415926536
Apr 29, 2014 | Office Equipment & Supplies
Hexagon calculator
I will not try to guess what that diameter represents, so I will give you all mensuration formulas for the area of a regular polygon.
s is the measure of the side, r the radius of the inscribed circle, R the radius of the circumscribed circle, and n the number of sides.
If the angle unit in your calculator is the degree, use 180 instead of Pi. Use the formulas with PI if angle unit is set to radians.
In the formulas on the last line of the display screen (the formulas with sine functions) the radius r should be R (circumscribed circle radius). cot is the reciprocal of the tangent function (cot(x)=1/tan(x) )
Apr 14, 2014 | Office Equipment & Supplies
Circle equation
If you know the center, measure the distance between the center and one point on the circumference. Measure with the opening of a compass and report on a ruler, or use a ruler.
Take the measure of the radius and multiply by 2. Any other indirect way of getting the radius does not constitute a measure but a calculation.
The diameter of a circle enters in two formulas.
Length of Circumference: C=Pi*D (D diameter) ====>D=C/Pi
Area of the disk A=Pi *D^2/4 =====>D=SQRT(4*A/Pi), SQRT is the square root operation.
Dec 31, 2013 | Office Equipment & Supplies
I have a problem concerning radians and angles
About 146 and a half degrees.
If this is homework, be sure to show your work.
Oct 22, 2013 | Office Equipment & Supplies
To graph a circle with radius 4
Press [2nd][PGRM] to open the (DRAW) utility. Scroll down to reach the line 9: Circle( and press ENTER. Complete the command by supplying the coordinates of the circle center and the radius.
Circle(0,0,4) draws a circle with center at the origin (0,0) and radius 4.
By the way the equation of a circle is not a function. You have to cut it into the upper brach and the lower part to graph it.
y=+SQRT(16-x^2) and y=-SQRT(16-x^2)
Sep 01, 2011 | Texas Instruments TI-84 Plus Silver...
How to find the length ot the arc ,a circle has a radius of 45cm.
You can not do it unless you know the measure of the central angle sustending (supporting) the arc. If the angle is known, you use the proportionality relation that follows:
If angle is in degrees
(length of arc) / circumference=(measure of central angle sustending arc)/360.
Here the circumference is 2*PI*radius.
If angle is in radians , the relation is somewhat simpler,
arc length= (radius length)* (angle measure in radians)
It is clear that in the last relation, the unit for the arc length is the same as the unit for the radius.
Jul 15, 2011 | Casio FX-300MS Calculator
What is the pi button
Pi is a mathematical constant whose value is the ratio of any Euclidean plane circle's circumference to its diameter; this is the same value as the ratio of a circle's area to the square of its radius. It is approximately equal to 3.14159265 in the usual decimal notation.
Mar 05, 2011 | Casio FX82MS Scientific Calculator
Analytic geometry
assuming the question is what is the circle equation?
and if (-2,2) is the center of the circle
the equation should look like this: (x+2)^2+(Y-2)^2=R^2
And now only R is needed.
given 2x-5y+4=0 equation of line perpendicular
we can rearange the equation to be y=(2x+4)/5
from that we can see that the slope of the line is 2/5
And from the fact of perpendicular line we can say that the slope
of the radius line is -2/5.
The motivation now is to calculate the distance between the center of the circle to the cross point of the radius with the line perpendicular
For that we would calculate the radius line equation and compare it to the equation of line perpendicular
As mentioned earlier the slope of the radious line is -2/5.
So the equation is y=-2/5x+b and b can be calculated by using the center of the circle coordinates
2= - (2/5)*(-2)+b ------> b=2-4/5=1.2
radius equation is y=-(2/5)x+1.2
Now the cross point is calculated by comparing the equations:
-(2/5)x+1.2=(2x+4)/5 --> -2x+6=2x+4 --> 4x=2 --> x=1/2 --> y=1
So the cross point is (1/2,1).
The distance between the points is calculated by the following
Formula:
R=SQR(((1/2)-(-2))^2+(2-1)^2)=SQR(2.5^2+1^2)=SQR(6.25+1)=
SQR(7.25)
Therefore the circle eq is (x+2)^2+(Y-2)^2=7.25
Oct 26, 2008 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
117 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
