Question about Lite On Computers & Internet
I need to see if there is an updated driver for my Lite-On CD-Rom LTN-52915 I only have dial-up internet and can't wait five hours for your program to download just to find out.
    President:
  • 1,901 Answers
Here's a link:
http://www.nodevice.com/driver/LTN-5291S/get35028.html
The download is only 420 KB so it shouldn't take too long.
Good luck.
Posted on Sep 13, 2008
I have a particular program disk that is not being recognized by the CD-ROM reader in my desktop. Other disks are recognized and the one in question works on my wife's laptop computer. I'm running...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Apr 24, 2011 | Lite On LTN-4891S Internal 48x CD-ROM...
Cd drive not reconized missing driver
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they are probably old and faulty ?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 20, 2011 | Lite On LTN-4891S Internal 48x CD-ROM...
I have a lite on ltn-4891s and I keep getting this message Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) I went to the lite on website but...
its fine any model woudl work just download any internal cd drive driver. there is even a stock one in windows. just go to device manager .. right click my computer, prop-device manger- then you will see th yellow or red arror for the drive and click uninstall driver or update driver. if you click uninstall driver then reboot and it will find the driver on the reboot. also make sure you dont have it set up via a jumper as master and have another drive on the same cable as master. switch the jumper to slave (instructions are on the cd drive itself) and that shoudl also fix it let me know
Mar 17, 2011 | Lite On LTN-4891S Internal 48x CD-ROM...
IDE master/settings jumper position for slave on LTN-301 CD drive?
look on the back of the case and their will be some letter MA,SL.CS
the most common position is the middle selection should look like this
slave
hope it helps dont forget to rate
Jan 07, 2011 | Lite On LTN 301 (LTN-301) Internal 32x...
I lost the driver
It does not look like it burns CDs. Here is the Features of the LTN-486S.
  • 48x CD-ROM with Pure-CAV Technology.
  • E-IDE Interface, support all PIO, MW-DMA, Ultra DMA-33 modes.
  • Support Power Saving Function.
  • Support High Speed Digital Audio Extraction ( DAE ).
  • Support High Speed VCD Data Extraction.
  • Support Plug & Play; Emergency Manual Eject.
  • High Speed CD-Audio Playback Technology to Improve Audio Playability.
  • Access all format CD, CD-R, CD-RW Title & Disc ( support up to 99 mins ).Easy-TrayR Design for both horizontally & vertically use.
  • Gear-Driven Tray Loading Mechanism to improve reliability.ABS Auto Balance System ( 486, 485 ) Mecha to Reduce Vibration R Noise.
  • WSSR Wire Suspension System ( 483 ) Mecha to Reduce Vibration & Noise.
  • Jul 01, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
    CD rom drivers problem.
    hmm...in device manager, are they both 'clean' meaning without any marks on them?
    Mar 10, 2008 | Computers & Internet
    Can not find drivers to reinstall lite-on "ltn 487t" DVD/CD-ROM drivers
    If Vista, some... most manufactors don't have drivers for devices that didn't sell alot. Try new DVD/CD-Rom.
    Feb 13, 2008 | Computers & Internet
    CD-ROM will not read any disc
    well try to clean the lens with a clean and dry cotton swab. ir you have a compressed air duster for electronics, use it also. remove the drive and open the cover. look for small like circle glass(lens) clean it. use also the compress air duster by hitting the below parts of the lens assembly to remove accumulated dust and test. if the problem persist, its about time to replace your drive. good luck!
    Feb 06, 2007 | Lite On LTN 323 (LTN-323) Internal 32x...
    Computers & Internet Logo
    160 people viewed this question
    Top Lite On Computers & Internet Experts
    John Anderson
    John Anderson
    Rommel Balcita
    Gbenga
    Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
