Question about Dishwashers
Cannot change the heating element on my Dishlex Global 300 dishwasher
    Genius:
  • 1,239 Answers
Hi try the link www.howstuffwork.com
Posted on Sep 13, 2008
2 Suggested Answers
  • 713 Answers
SOURCE: dishlex global 300 : dishwasher dispenser won't
Hi just read your posting.The problem could be a faulty dispenser coil ,or the wires to it are faulty or the computer is faulty.Try selecting a normal eco wash and when you push the start button to start the machine hold the button in until the pre wash light turns off.This should make the dispenser activate straight after it fills.The only way to test which part is faulty is with an electrical meter.Have you or can you borrow one.If so then I can guide you step by step in finding the fault.please reply with additional information and I am sure I can help you further.Looking forward to your reply.
Posted on May 22, 2011
I have a Dishlex Global 300 DW. The Mains safety switch trips on Rinse cycle. Heating element has continuity and works on wash cycle. There are no leaks.
call an electrician to check the insulation for ground leakage and breaker capacity for current use
it will most likely be tripping from moisture across the active and neutral wires somewhere
Dec 05, 2016 | Dishwashers
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Global 300 Dishlex draining problem
is the float switch clear of debris so it can go down to its lowest point to shut off the pump,, a peice of food could be stuck in it, keeping it up just enough to keep it running
Jan 03, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwasher power overload
Check heating element in DW and all parts associated with it located on the inside of DW under the spray arm. It could also be a problem with the control panel,Call technician.
Dec 09, 2007 | Dishwashers
Dishwashers Logo
304 people viewed this question
Top Dishwashers Experts
