Question about Sony STR-DE535 Receiver
SONY STR-DE535 Whenever i turn on the receiver, it will immediately stop playing and will give the message "PROTECTOR"
  • 2 more comments
  • ksmith5075 Nov 06, 2008
    My Sony STR-DE515 flashes protect, Any thing I can do or check personally before taking it to be serviced?
  • sivadcu Dec 17, 2008
    Receiver flashes "Protector" when turned on.
  • Anonymous Dec 26, 2008
    When turned on, the receiver works for a minute then switches to protect mode.
  • sivadcu May 11, 2010
    What are amplifier IC's and how do you change them?
    Genius:
  • Sony Master
  • 1,550 Answers
Change the audio amplifier IC´s are in short circuit that´s why your device go on to protection mode.
Posted on Sep 13, 2008
Problem solved. For all those who have this problem and have checked speaker cables are not shorted etc first - here is the solution. Turn amp upside down and remove the 6" (approx) square metal plate that is screwed on to the base. With the front of the unit facing you, the circuit board board on the left (Input board) is where you'll find two ICs labelled IC501 and IC701. Look carefully at the solder joints and you will hopefully see they are darker and grottier than most of the other shinier solder joints elsewhere on the board. Re-solder all the legs of each IC - 15 pins on each. You may need to remove the old solder first. Check for other near-by components that also have bad looking solder joints and re-solder those too. The two ICs are part of the protection circuitry and they appear to get pretty hot causing part-melted and part to completely broken solder joints. People who have the symptom of permanently in Protection mode should also be able to solve their issue with this solution. Hope this helps somebody out there. Cheers Dave
Posted on Jan 26, 2012
Whenever i turn off the mains, i get a
that is normal when you unplug from wall it looses all settings and the reciver thinks it is a brand new reciver and it plays the demonstration
the only way to stop this is not turn it off from the wall
switch it off from the front
May 09, 2010 | Sony STR-DE445 Receiver
This amp wwhen turned on, dosplays 'PROTECTOR' on teh display, what is this telling me?
Disconnect all the speakers and unplug it for 5 minutes. Then turn it back on without any speakers plugged in. If it doesn't say protector, then you either have a shorted out speaker or wire. The amp is in protection mode which is designed to keep it from burning up. If it still says protection, then it will need to be repaired as it is too late.
Dec 19, 2009 | Sony STR-DE535 Receiver
Blown Stereo Receiver
If the output transistors are shorted they cause burns on the resistors and even even blow the AC fuse and your receiver will not come ON. I used to enjoy fixing, these AMPs this was many years ago. Any how, repairing this unit will be more than a $100.00 my advice to you is BUY a NEW 1.
Good luck
N Sabre
Nov 08, 2009 | Sony STR-DE535 Receiver
What fuses does the sony str-de535 need
I beleive it is a 6.3amp gma. It will be printed on the circuit board next to the fuse holder and on the fuse itself. If it is open(blown) you probably will need to replace a set of the output transisters (mp1620 and mn2488). DO NOT use a slow-blow fuse this will cause more damage to your receiver.
Oct 21, 2009 | Sony STR-DE535 Receiver
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Power On Displays Flashing "Protected"
The audio amplifier IC´s are on short circuit.
Jun 15, 2008 | Sony STR-DE535 Receiver
Protector mode SONY STR D1011S am fm receiver
I've had this happen, it's when you have speaker wires crossed.....
Dec 27, 2007 | Sony STR-DE945 Receiver
Protector message
The only way to reset protect is to eliminate the problem which activated it. Problem may be insufficient line voltage or unit's output circuit. Have unit checked out by prof, tech
Sep 30, 2007 | Sony STR-DE825 Receiver
Sony STR-DE535 Receiver Logo
429 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
