Question about Dryers
Dryer not getting hot
My dryer doesn't get hot , everything else seems to be working fine. any ideas. is this easily fixed and can i do it myself. thanks
  • 5,911 Answers
For future reference, when you post questions to this forum, please provide the make and model number of your appliance as all dryers are not built the same. This makes it much easier to diagnose and attemtpt to provide you with a viable solution.
I'm assuming when you stated that everything else seems fine, that the drum is spinning, but the dryer just isn't heating. The following link explains some of the common component failures associated with a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. If you can't remember the last time you cleaned the dryer exhaust vent, or never have, it may be a good time to start routinely cleaning it. This is the number one cause of dryer failures. The reason I mention this is because, if you replace a failed component and leave a dryer in a condition where it is not provided the proper air flow, the dryer heating circuits will overheat to the point of failure (again). I've seen many people replace parts, only to have them go bad again within a day or so, because they were unaware of clogged ventilation. Not to mention, this can cause a potential fire hazard, or breeding ground for rodents. If you have an exhaust vent outside that does not have a louvered cover, I would recommend it. Certain bird species love to build nests in vent lines as well as mice. You will, however, have to go outside and clean this area frequently, because lint likes to accumulate on the louvers. NOTE: DO NOT, however, put a screen over the exhaust. Because of the fine mesh of a screen, it tends to collect everything and clog easily.
Here's an additional link that gives you the basic requirements for proper dryer vent installations (just in case you have questions or concerns):
http://www.fixya.com/support/r389357-dryer_ducting_installation_tips
Read through the links I provided and let me know if you have any questions and require additonal assistance. I hope this helps you.
Posted on Sep 13, 2008
We have an lg dle3777w dryer and it doesnt seem to get very hot to dry the clothing...it takes many cycles to get one load dry...any ideas???
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG DLE3777 Electric Dryer
My maytag clothes dryer does not get hot anymore.
is this an electric dryer? if I had the model number, around the hole where you put the clothes in, I could tell you better if this is something you can do yourself. it may not be the heater, it could be a thermal fuse cutout giving you trouble. let me know.
Oct 13, 2009 | Maytag Dryers
LG dryer will not get hot
ur heating element is broken..order a new one, out it in, and presto!
Oct 11, 2009 | Dryers
Dryer is running fine just not getting hot
It sounds like the thermal fuse or heating element are defective. Both components are easily checked with an ohm meter or multimeter. The fuse is usually inside the back of the dryer by the exhaust duct. Both components should have continuity, if not they need to be replaced. Sure hope this helped.
Jul 20, 2009 | Roper REX4634KQ Electric Dryer
My dryer is not blowing hot air anymore
most likely the thermal fuse 279769 or the heating element 279838 if this is a newer dryer...whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool Dryers
My electric whirlpool senseon dryer won't heat
lint screen on top///repl/thermal fuse in rear of dryer, if screen inside dryer remove front bottom panel, next remove blower housing on top off is the other thermal fuse ,, gurantee fix
Nov 29, 2008 | Dryers
Older whirlpool dryer gets too hot when using automatic setting
After 25 years,your automatic sensor may be bad. RepairClinic.com might have one. Clean everything inside while you're there.
Nov 26, 2008 | Dryers
Dryers Logo
46 people viewed this question
Top Dryers Experts
