Question about Hobart 24 in. LXIC-5 Built-in Dishwasher
BUTTONS THE FILL AND DRAIN BUTTINS DONT TURN ON OR OFF. AT FIRST IT WAS LEAKING BUT I FIXED THAT NOW THE BUTTONS DONT WORK
  • 640 Answers
Is the display on?when you press any button do you hear a beep?
Posted on Jul 31, 2007
Water is draining from hot tub after its filled & dont know why
Hi Mary,sounds like your drain stopper may not be closing tight.Try removing the stopper by turning it counter clockwise,then jam a small rag in the drain as tight as you can to stop the water and fill the tub.If it still leaks then the drain plug where the stopper goes may have to be re-sealed or one of the jets may have a leak.If the tub is over a ceiling do not keep re-filling the tub you will cause major water damage to the rooms below.
Jan 05, 2014 | Leisure Time Filter Clean 1 Quart - 12...
The stereo keeps turning off an wont come an sometimes buttins on stereo dont work
the power supply internal from the radio is faulty. However test bad contacts, clean contacts very well, test the fuse for bad contacts , corrosion, and clean it.
Otherwise , you must go the repair shop Tv for fix it.
God bless you
Sep 28, 2012 | 1996 Dodge Avenger
Wont fill with water at first then later when it did it didn't wash it only had an FL on the screen
ok it can be many cause to this code ,,we have to try a few fixes,,fl means flood condiction.did we use to much detergent,.,,if so just run a rinse cycles..now the unit thinks it overfilling for some reason,,,next check and make sure you dont have a kinked drain hose,,make sure the unit can drain is draining properly check the inlet vavle for leaks/hose for leaks ,,do water leak in tub while unit is off,,try some of theses fixes,good luck
Sep 09, 2011 | Kenmore Washing Machines
Washer leaks when filling,fill by pail no leak
Pat it sounds like you pressure switch or hose to it is bad.your washer isnt leaking its overflowing the tub right?I dont understand the rest of your question so ill leave it alone..
Nov 15, 2009 | Washing Machines
Buttons do not function on my d80
Some of those buttins work in combination with the two dials (i.e., setting ISO and white balance, etc.). Hold a buttin down and user the knobs simoultaneously.
If this is not the issue, please describe specifically which buttons are not working.
Apr 14, 2009 | Nikon D80 Body Only Digital Camera
Fills up when not on
you have a leaky water valve it leaks because one of the solenoids in the valve is stuck open, the unit senses the water in the drum from the leak and therefore must be drained before it can start a new cycle, replace the water valve.
Apr 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
I HAVE A PROBLEM WITH 19in NO DISPLAY IMAGE
Yes, i fixed mine! I forgot to say that the power-on button was broken. So after suffering so long a pressed the buttin in untill it kind of disappeared. It might have been blocking something, i dont know.
So with no power on button it works fine, dont know if this is a good solution, but it worked for me !
Feb 24, 2009 | BenQ FP71G 17" LCD Monitor
Maytag Neptune Leaking Water
pull the frount panael at the bottom and look there early model neptunes would leak around the door seal they made a kit to fix them but i dont know how old yours is so i cant tell you if thats it check the obvious hoses etc your drain pipe could be cloged the one your drain hose goes down in and just barley running over when the washer drains tell your husband to fill it then then switch to drain and listen to the pipe will sound like a bottle filling up when it drains or he will see it running over while it fills look under the bottom panel for leaks hope that helps
Dec 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Diswasher Leaked, now Won't Work
if you see a float inside of the dishwasher make sure its cleaned well.that float tells the control board when to drain and to fill with water.the symptom you descibe tells me its trying to drain,make sure the float moves freely.if you dont have a float you will see a metal probe clean that up as well.try this and if it doesnt fix the sensor may be part of the drain body and it has failed(leaking).
Aug 27, 2007 | Bosch SHU9915UC Dishwasher
Freeze
Hold the power button and the menu button simultanously for about 20 seconds. Wait at least another 10 seconds, and then turn it on again.
Aug 14, 2007 | SanDisk Sansa e250 MP3 Player
Hobart 24 in. LXIC-5 Built-in Dishwasher Logo
85 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
