Question about Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
The connector on the back on my TV has come off.
The connector where you connect the cable has fallen off the TV. How do I fix it?
  • Anonymous Nov 22, 2007
    The connector on the TV for connecting the cable has broken off. How can I fix it?
    President:
  • 3,130 Answers
It depense on if the connector is part of the tuner or a ant block. it its an antenna block it will be a small block shaped device that has a wire running to a silver rectangle and that would be the tuner. You could get one from a parts distribitor that handles sharp parts and shouldnt be too hard to replace but you must know its always better to take the set to a repair person if you have no electronic background!!!!! If you see where the connector came off of and its a skinny rectangle then its part of the tuner and a repair shop may be able to solder another terminal in place or even a connector wire. Good Luck
Posted on May 20, 2006
  • Larry  Dillon
    Larry Dillon May 20, 2006
    If it is the tuner then get the # on the tuner and go tohttp://www.ptscorp.com and they sell replacements if you can get someone to install it for you?
Why is my sony bravia not tuning in and can you tell me how to fix it
The TV is probably not seeing the signal. Are the cords connected in the right slots on the cable box and TV (cable TV wire into the cable input connector on box, and cable out to the TV in the cable out connector on the box, and then connected to the right connector on the back of the TV)? Or, maybe you may need to go into the TV screen options and choose the the right external source that will allow the TV to see the signal.
Sep 18, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do i fix the line on my vizio 60 inch smart tv?
Good day,
Eh, lines are usually due to the screen being hit and an electrical open appearing in the panel. Sometimes, if the device has been knocked or fallen, the panels connector may have come loose. I would open the TV and look for the video board to see if the connections are still good. Give them a wiggle and see if the line clears.
BE CAREFUL OF HIGH VOLTAGES INSIDE THE BACK !!!
Good luck...
Jul 15, 2014 | Televison & Video
On back no switch to connect my pc
Hi I got the same model TV and it a very easy fix. You wont find a pc connector on the back of the tv as you mention but you will see a "15 pin connector" as they are called because thats what they have if you count the number of tiny holes in it. Anyway, you can find this at any electronic store including at home depot at the audio/video section. Once you get it connect one end to back of tv and the other to the side of your laptop which is where you will find it. Be sure to get a long enough cable by roughly calculating how far you tv is from the computer. you can spend up to $50 but a $10-$15 cable will be as good. good luck.
Sep 10, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The cable hookup has fallen out of the panel in
You need to find someone to reinstall the connector. If I was closer it might be a simple repair. Email me at.... poikaa@yahoo.com
Feb 15, 2010 | Vizio VW42LF 42 in. LCD HDTV
The cable connection on my tv broke off how can I connect back to the cable
On most TV sets, the cable connector (also called an F-connector) is just press-fitted into the metal housing of the tuner (which selects the channels). It's not very strong mechanically and is pretty easily broken by tripping over the cable, moving the TV if the cable is too short, or often by cable technicians who overtighten the cable connection with a wrench.
The good news is that this can be fixed. There are two ways. The simple method is to replace the tuner. It's quick but costly as a new tuner may run $100. The second way is to replace the broken-off F-connector. On some sets it's possible to do this without removing the tuner, but not always. This repair may take a little more labor time, but saves the cost of the tuner.
Either way, this is a repair that's best left to a professional. Without the soldering skills and equipment needed, it's possible to do major damage to the TV and tuner circuit boards. I would recommend getting an estimate for the repair from a shop in your area. Yes, there are still places that fix TVs, but they are getting scarce.
Another possible "fix" is to forget about using the TV cable connection and use a VCR or DVR to tune the channels, and just use the TV's video and audio inputs. It doesn't repair the TV, but it gets you back onto the cable.
I hope you've found this helpful. Thanks for using Fixya!
Jan 31, 2010 | Samsung TXM3297HF 32" TV
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
VHF/UHF cable connector broke off from back of televison
well it can be fixed but you will need rf connector their cheap send it to a tv shop they will fix for 30-50 bucks sorry
Apr 03, 2009 | Televison & Video
Broken cable connector
Yes this is a cheap fix that should only cost between 15.00 and 25.00 US if you take the TV in to be repaired! dont have them come to your house as it will cost much more!!this can be fixed in a few minites so dont let them take advantage of you!
Please rate my response to your question!
Feb 02, 2009 | Recoton Advent Advent DV1418A 14 in....
Coaxle cable (from aerial on roof to TV or top box)
I believe that you use the same type of connector as in the UK.
If so, this site or this video should help you.
Even if your connector is a slightly different design, the principles are the same.
Hope this helps,
Matt
Mar 05, 2008 | Audio Players & Recorders
My cable has disconnectd.. well fallen off the end of the cord. This is the cord form the aerial(on roof) to the back of the tV. I have no picture, as the connections on the end are loose. Can...
Are there 2 wires that can be seen? And is it flat looking or is it round cable with silver braided wire with white center insulator with copper looking center conductor? If it is the latter you can purchase screw on connectors at most electronics shops. Example...Radio Shack, Home depot, Lowes etc. Good luck and happy tv watching. Jay
Mar 05, 2008 | Televison & Video
Sharp 27DV-S100 27 in. TV/VCR/DVD Combo Logo
100 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
