Just recently probs with above, seems the door wont open to let the tab out, program runs for the normal amount of time but is interupted with 30 beeps before draining. also seems a bit cool.
Hi
The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent the door will not open
1. Press the Start button.
2. Type msconfig in Start menu or click 'run' and type msconfig.
3. Open the program. (Click msconfig icon if it doesn't open automatically)
4. Also, open the command box. Click Start > run > and type cmd.exe and open. (If the above method does not work, using "msconfig", your "System Configuration Utility" program should open on your screen. 5. Click on the "General" tab on the utility program. Select the "Normal Startup" option. Click "Apply" and "Ok" to confirm the change back to normal mode.
6. Follow the on-screen prompts to restart the computer. Your computer should reboot normally.
7. IF this doesn't work:Click on the "Boot" tab in " msconfig" > the "Safe boot" option should be unchecked.
IF that doesn't work, go to "msconfig" again and click the Startup tab. Disable all startup programs or, if you know which one is causing the problem, just a single program.
I had the same problem today. The good news is I fixed it without replacing any parts. I tried a few things which may have worked so I will list them all. I'm not sure which one worked so try the easy ones first. Fill the salt and rinse aid depensers up. Once it starts beeping continously close the door and let it drain itself. Do this several times. Turn it off and leave it for a minute between goes. With the power button light on leave the door open slightly for about 15minutes, mine beeped after about 7 minutes and it had reset itself. At the bottom of the dishwasher underneath there is an anti flood switch. My tray had water in it and caused the float to rise up and activate the switch which stops it from working. Easiest way to drain it is to pull the dishwasher out put down a load of towels and tip it backwards until all the water is gone. I found it easier to check for water through the right handside side panel, it comes off pretty handy.
I also removed the upper front cover to check the door catch switch. Just make sure its not broken and not wore down etc. I also sprayed it lightly with WD40.
Try disconnecting the wated inlet pipe at the back once you have turned the water off. Mine had a lot of pressure in it which it should probably should have but read somewhere else it solved their issue.
I then stripped both sides off laid the machine on its back, make sure to disconnect the water inlet pipe and took apart the drain pump. If your looking at the back its on the right hand side, mine was dark grey and was attached by two screws to the side panel. There is 4 or 5 screws which hold the drain pump together. Unscrew these and again there will be a build up of pressure and water released. There might be a foreign object stuck in here which will stop the blades turning. Check the espares youtube channel on how to remove this, thats what I did.
After all this mine didnt work straight away and I had given up. But I left the power on with the door open slightly and after 7 minutes it beeped and I was able to select a program as normal.
Maybe the turning over on its back and release did the trick Im not sure but give it a go. Good luck
The dishwasher's heater is likely shot. Get a new heating element. The same heater drys and the end but also heats the hot water during the wash cycle. No hot water = dirty dishes.
on most machines, the timer will not run if the water is not up to temp. if the inside is plenty hot mid-cycle, then your heating element is probably good. it is the thermometer that needs located and checked. if the inside is not steamy, then your heating element is the most likely culprit.
don't hate your dishwasher. it just wants to make sure that you get a full wash cycle at a hot enough temp. to get the dishes clean. good luck
This is usually caused by a driver or program that is wrong or corrupted.
Start in safe mode. Go to START then RUN then type MSCONFIG hit ENTER
This should bring up a window that has several tabs. Click on the tab labeled startup. Here are all of the software that is set to automatically startup in normal mode. Choose DISABLE ALL. Then Apply or OK and exit. The system will prompt you that it needs to restart. See if the system will now start in Normal mode. If so you are good to go. if you want something to startup again do the same as the above and select or "check" the items you want to start automatically. Do this until the problem returns and you've located the culprit.
However, if Normal mode did not return after the above steps, you may have to update the systems drivers, un install recently installed software or possibly restore system files.
I used the solution I found for a slightly different fault, ( this was the same fault but without the bleebs)
switch off mains and turn off water. Then disconnect water pipe and lay machine on it's back. Switch on electrics, and allow water to run out. Switch off electrics and stand machine up .Reconnect everything and hey presto I can hear two good things, the machine gently humming, and my wife telling me what a genius I am !!
Its not clogged. and will pop open it the lever is touched quite easily. Ps Matsui is a Curry's own brand in the UK.
